Some observations from commuting in a Crossfire.
Old Jun 12, 2012 | 05:35 AM
  #151
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Re: Some observations from commuting in a Crossfire.
The shell is very solid, but it's been sprayed flat black all over. The interior is wasted, and the car needs completely stripped and re-done. The engine/harness/ECM seem OK, we had it running while I put the T5 through its gears. I think Brandon is going to remove the engine and trans and try to sell the shell to someone that needs one. Cutting it up is not the plan at this point.
The swap kit will come with all the other associated pieces such as the starter, cross member, inspection cover, slave cylinder bracket, shifter, pedals, pedal switches, shifter boot, clutch fork, and of course the trans and bellhousing. There is also another very rusty T5 car out there that I'm having Brandon cut the tunnel out of for us. With the least cutting and using the smallest section possible, I think I'm going to actually weld in a real reinforced shifter opening from a real T5 car.
The CFI stroker motor can come later LOL
Old Jun 12, 2012 | 05:40 AM
  #152
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
How do you guys plan to handle the ECM, especially considering there was no CFI 5 speed? Obviously a custom tune is in order, but who's doing it?
Old Jun 12, 2012 | 06:10 AM
  #153
Jeffs82TA's Avatar
Originally Posted by chazman
The weather here in Chitown has been unbelievably fantastic so far this year. Usually, my 3rd gens are still sleeping this early in the year. But it's been so nice out, I've been driving my '83 Crossfire to work for the past several days. I'm also trying to decide if I want to sell it, so I'm spending more time behind it's wheel during my decision making.
First off, I think all of the money I've invested in the custom exhaust was money well spent. Yeah, if I had it to do over again, maybe I would have waited for a complete N10 system, like I had originally wanted, but whatever. The LU5's L-83 cam has a really nice lope with what I currently have when you're at a stoplight and sounds pretty good with the t-tops off. The functional hood flaps are always entertaining to me when they open and close - I guess I'll never grow up. The CFI may be much maligned, but it does provide good low end torque, even with it's 2.93 gear. It's too bad, GM didn't develop it with an L69 exhaust, manual trans and a 3.42/3.73 gear. It would have been a (relative) rocket.
One thing I noticed, is that on a 3rd gen, you can drive at highway speed with both windows down, without any undue noise, turbulence or most of all, resonance. Try that in a new car and see how many seconds it takes before you roll the windows back up. Plus, you can still rest your arm on the window sill and drive comfortably. You do sit lower than most of the SUV's, crossover's and sedans on the road today. I went through my bank's drive-thru and noticed that my roof was at the same level as the tellers drawer. The teller saw me and said, "hello chazman, didn't see you down there."
3rd gens handle great! You certainly won't have anyone in a modern car on your rear bumper on an on/off ramp if you don't want them there - that is for sure!
If I could change something, I wish I could have a little more power and a little more braking. I find that I have to slightly alter my driving style to compensate for the brakes. And........a T5 would be nice too.
You know, if I didn't have to worry about our winters, I could see myself using this car as a commuter more often. It does suck more gas than a newer car though, with premium at $4.65 per gallon around here, that's something to think about. Too bad I never found the right Iron Duke car to commute in.
I once had a 1984 4 cylinder 4 speed camaro that I did what you mentioned to it.
Replaced the 4 banger with a 1983 crossfire 305, edelbrock tes headers with the 84 style larger front y-pipe, 84-85 3" catback, 3.42 rear end with limited slip, 84 5 speed transmission, 84 vette ecm, functional 83 Z-28 hood. But later added Z-28 rims, springs & sway bars but kept the body stock looking.
I pondered with a H.O. conversion but liked the looks of the dual TBI's and the driveability.
By comparison to a stock 82 CFI trans am which my friend had it could easily beat it.
Do the swap and you won't regret it, always even got around 24 mpg average with that combination
Old Jun 12, 2012 | 06:36 AM
  #154
82tarecaro's Avatar
I don't think this would be too much of a problem. The auto computer should work fine. You should hook the park neutral switch from the auto to the neutral switch on the manual trans so the ECM thinks its in gear. On an auto car, the computer should adjust timing and idle differently when the car is placed in gear, so at the very least, you would want that to happen when you place the car in gear with the manual trans.
I have been running an automatic computer on my manual Mustang 5.0 for years, and it runs fine. On the Ford, the auto computer actually has a more aggressive tune.
Old Jun 12, 2012 | 07:51 AM
  #155
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Plan A is to wire the park neutral signal to the ECM permanently together so the ECM always thinks its in park. This is what I typically do on all my other swaps. It always works because as far as I know the ECM only uses the park neutral signal for idle speed adders for AC and cooling fan enable etc. There is no special ignition timing for park vs in gear, it's all based on rpm and engine load. Plan B is to wire the park neutral switch signal for the ECM to the clutch pedal. So when the clutch is in the car thinks it's in park. The issue with that could be idle quality with the clutch out and trans in neutral. Plan C is to get a HAM board and use a later TBI 746 ECM so I can start with a real factory 5spd tune. Plan D is a HAM board and the EBL.
Old Jun 12, 2012 | 08:25 AM
  #156
82tarecaro's Avatar
There should be a neutral switch on the t5 (at least there is one on a Ford t5) and I wired that into the neutral signal to the ECM that used to go to the neutral switch for the automatic. It helps to have a shop manual with a wiring diagram. I needed to see the schematic and it made it alot easier to figure out what wires to use. This was part of a HO swap into a TBird, so the factory wiring manual made my life a whole lot easier.
The HAM board would be beneficial later on when you swap a bigger engine in. I don't think you will need it now, but it sure would make the car run a whole lot better.
Old Jun 12, 2012 | 08:50 AM
  #157
Jeffs82TA's Avatar
when I used a 84 vette ecm on my conversion, I never had idle problems.
Old Jun 12, 2012 | 09:30 AM
  #158
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
GM T5s don't have a neutral switch. There is a switch for backup lights and thats it.
I don't really understand how this worked. The L83 is a larger engine with different injectors(i think) with different cylinder heads and cam. I can't see how a stock vette ECM controlled the LU5 that well without any other changes to the tune. It is absoultely critical that this car operates PERFECTLY as if it had came from the factory with a T5. No burps, hiccups, stalling or stumbles will be tolerated.
If I had a way to open the L83 tune and mix it with the LU5 tune and dump it back in the stock ECM I would. But by the time I go to all that trouble I might as well just put the HAM on the 746 ECM I have laying around(thats already modded to be able to switch chips in and out) and roll with it. Then I could tune it like any other TBI car which I've already got experience doing.
Old Jun 12, 2012 | 10:01 AM
  #159
Jeffs82TA's Avatar
If I had a way to open the L83 tune and mix it with the LU5 tune and dump it back in the stock ECM I would. But by the time I go to all that trouble I might as well just put the HAM on the 746 ECM I have laying around(thats already modded to be able to switch chips in and out) and roll with it. Then I could tune it like any other TBI car which I've already got experience doing.[/quote]
Just saying it did is all, I had both ecms 83 LU-5 and 84 L83 ... both ran the car fine but the 84 ecm gave the car a much different sound and the car also accelerated much differently.
perhaps the ecm came from a 4+3 vette who knows, but either way it never died with a/c on or coming to a stop.
The only problem smog wise was I chose a older donor engine then the car so it failed in that aspect however it passed the sniffer test with ease.
Old Jun 12, 2012 | 10:46 AM
  #160
82tarecaro's Avatar
I never worked with a GM T5. Where does the computer get the neutral signal?
Old Jun 12, 2012 | 11:20 AM
  #161
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
From the automatic shifter. There is a set of contacts in the shifter that operate the park neutral switch to start the car and for the ECM, as well as a switch for the reverse lights.
Old Jun 12, 2012 | 11:31 AM
  #162
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
I believe that the LU5 and L83 cams are the same.
Old Jun 12, 2012 | 11:42 AM
  #163
82tarecaro's Avatar
But what is the equivalent of that switch on the t5 setup? Or is there no neutral sensor anywhere?
Old Jun 12, 2012 | 12:04 PM
  #164
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Are the injectors the same too Charlie? I'll have to look that up.... Even with the same cam and injectors I'm shocked that the L83 ECM would run an LU5 so nicely. Engine displacement is a large part of the calculation a speed density based ECM uses to determine injector pulsewidth. It's either a miracle or the old CFI ECM has the ability to trim fuel back that far. Or I'm totally wrong about the CFI ECM and it's Alpha-N based or something....
Jeffs82TA, did your fuel mileage suffer at all? Hot or cold starts good or bad?
Old Jun 12, 2012 | 12:06 PM
  #165
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
There is no neutral input to the ECM in a manual trans car. The tune is different and thats where the compensation is made.
Old Jun 12, 2012 | 12:09 PM
  #166
chazman's Avatar
Axle/Gears: BW 3.45
I think that the L83 injectors flow more....but I'm not 100% on that.
Old Jun 12, 2012 | 12:34 PM
  #167
Jason E's Avatar
I need to move closer to you two...I'd have too much fun
Old Jun 12, 2012 | 12:42 PM
  #168
Jeffs82TA's Avatar
I took it to Minnesota once in -30 temps and it fired right off and cold/warm cycled perfectly. Drove it through Canada one summer and it averaged about 24mpg each fill up. I know for a fact nothing on motor was changed as it came from a wrecked 32k mile 83 Z-28. Injectors and all electronics were LU-5. Car probably really would have been nice with ported intake and better heads but as it was it was a strong running car. The LU-5 never hurt the T-5 whatsoever. It could dip into the 18mpg ramge depending how you drove it but if driven nice it always did good.
Another thing I did to it was run L-69 electric fan and kept temps around 205 and noticed it had much crisper exhaust note and didn't have the wet fuel puddling idling issues. When it was kept hotter it sounded more like a TPI engine.
Old Jun 12, 2012 | 12:57 PM
  #169
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
After thinking about this and getting more info on your setup I think you may have experienced a perfect balance of innacuracies that equaled out to the correct answer. The ECM thought the engine was larger, but also thought it had larger injectors than it had. Since you had it on a smaller engine with smaller injectors the pulsewidth between the 2 combinations probably ended up being very similar in many conditions. In other words, the ratio of injector size to engine displacement was the same between the 2 combinations resulting in the same pulsewidths in many load conditions, hence the ability for both ECMs to do the job. I'd guess the ignition timing on the L83 was more aggressive, but probably not more than premium fuel could handle on an LU5.
Old Jun 12, 2012 | 01:00 PM
  #170
chazman's Avatar
Axle/Gears: BW 3.45
The best mpg mine ever got was about 18 on the way home from Indy in 2008. I currently get about 14-15 mpg in mixed commuter driving.
Old Jun 12, 2012 | 01:03 PM
  #171
Jeffs82TA's Avatar
did you have the stock exhaust ?? That probably helped mine be a bit more efficient too. I know the LG-4/LU-5 exhaust keeps those engines choked up.
Old Jun 12, 2012 | 01:24 PM
  #172
chazman's Avatar
Axle/Gears: BW 3.45
Just a little tidbit which may or may not give a peek into the ECM's logic.....
When I first got the car it ran terribly. I fiddled with a bunch of different things in order to get more smoothness and performance out of it. I played with the initial timing advance and found that it ran best with some really crazy advance. I think that I actually added another 10-12 degrees of advance to the base factory settings, and it ran much better and never pinged once. This really made me nervous so I backed the timing back afew degrees.
Later, I decided to pull the IACs and see how they looked. They were completely gummed up and stuck in what I think was the full open position. I cleaned and lubed them so they'd operate normally. My idle smoothed dramatically, and when I took it around the block, it pinged like a ****. I dialed back the timing to a more normal advance and it ran great.
Old Jun 12, 2012 | 01:27 PM
  #173
chazman's Avatar
Axle/Gears: BW 3.45
At that point, I had the LU5/LG4 exhaust manifolds but with a 3" exhaust. Since then, I've switched to L69 exhaust manifolds (with the same 3" exhaust) and it runs better.
Old Jun 12, 2012 | 01:44 PM
  #174
Jeffs82TA's Avatar
Mine had edelbrock tes headers designed for the 84 305 h.o. the cat was a 84-85 4 bolt flange style one and the catback was edelbrock but cant remember but it was a 3" inch system.
I have a 82 vette as well and it responded quite well to increasing the coolant temps over stock so I am wondering if that help fuel atomization and helped eliminate fuel puddling.
I would be interested to see the timing curves and fuel mapping of a L-83 over a LU-5. I think if GM had unchoked the LU-5/L-83 the 5.0 h.o. would have never come to be. I do know the Lg4 and I think the LU5 have max timing set at 32 degrees where the H.O. got 36 degrees due to the knock sensor.
or something like that. I cant remember if I changed esc modules or not. I did this conversion back in about late 84 or so. Believe I was also running a stock TBI pump
Old Jun 12, 2012 | 06:47 PM
  #175
yaj15's Avatar
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
What are the engine specs for the LU5? What are the engine specs for the Corvettes L83? Which engine was produced first?
I am wondering if GM did the same thing to the Cross-fire cars like they did with the TPI cars.
We all know that the TPI system was originally designed for the 305. At that time GM was considering stopping production of the 350.
My understanding (please correct me if I am wrong) was that GM then decided to keep producing the 350. Since both the 305 and 350 are in the same engine family GM stuck the TPI system on the 350. My assumption is this allowed them to offer the 350 to the public while still meeting the emissions and fuel economy standards the government wanted.
Did GM design the Cross-fire system with both the 305 and 350 engines in mind? If they did maybe away to start looking for some performance gains would be to look at what GM did different for the L83 motor compaired to the LU5. I am assuming that the Covettes timing and camshaft specs should be simular to the LU5 just a little bigger. What are the compression ratios and fuel pressures between the LU5 and the L83?
Old Jun 15, 2012 | 11:52 AM
  #176
Jeffs82TA's Avatar
This is probably the best idea of what happened. I have never tuned or fiddled with proms or anything like that, I know the stock L-83 prom was in the ecm. Think I just found a happy medium is all, always wondered what happened to that car since after I sold it I never saw it again so perhaps it went out of state or something.
Old Jul 2, 2012 | 11:01 PM
  #177
chazman's Avatar
Axle/Gears: BW 3.45
Starting to collect parts for the T5 swap. Got a shift plate and a CORRECT '83 leather shift **** from two members here.
The shift plate was a disappointment. It had sort of an adhesive smeared all over it (like Liquid Nails?) and then painted black to hide it. It wasn't apparent in the pics but was the first thing I noticed when I opened the box. I've been trying to fix it, but in the process of removing whatever was on there, I've altered the finish. If I knew, I would have passed on it. I applied Vaseline and let it sit for afew hours so whatever that stuff was would absorb oil and soften and then I scraped it off with a razor. But you can see where it was in the pic. I'll work on it abit more, but I might just get another one. The leather boot is coming along, though.
The **** is a find though. Note the 2 year only, vertical stitching. It should be easy to restore.
All I need now is an '88 and up, hydraulic clutch, WC T5. The one I thought I had a line on turned out to be a 4.05 1st gear S10 trans. I can get an '83 cable clutch T5 locally, but I'm holding out for a hydraulic WC unit.
Old Aug 10, 2012 | 01:42 PM
  #178
chazman's Avatar
Axle/Gears: BW 3.45
Looky what I picked up today.
The original plan was to source a WC V8 T5 with a 2.95 1st gear and a 3.42 posi rear for my '83. Well........that fell through.
But minutes from my house I found this one for a good price. It's a T5 from an '84....erm....Iron Duke. It has some steep gear ratios. 3.76 1st, 2.18 2nd, 1.42 3rd, 1.00 4th and .72 5th. With this T5 I can keep my stock 2.93 posi and get great torque multiplication. I'm not really too concerned about RPM drop off between gears, since the CFI is a low RPM torquer. Plus, the gears are way more tightly packed than the current 700R4 in it. If you crunch the numbers, this trans with my 2.93 rear will multiply as much torque in 1st gear as a V8 T5 with a 3.73 rear.
I just degreased it before these pics. Now to find the rest of the "swap" parts.
Old Aug 10, 2012 | 02:30 PM
  #179
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I'm sure you did your research, but are you certain that the input shaft from an Iron Duke T5 is the same as a SBC input shaft?
Old Aug 10, 2012 | 02:44 PM
  #180
HiPerf_Chevyman's Avatar
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
I got one from a 1984 2.8 and the Inputs were diffrent from a 305 T5. so yea I'd check on that. lol
How much did you pay for that t-5? Im considering selling mine, but IDK what its worth as i dont know the mileage on it...
Old Aug 10, 2012 | 03:18 PM
  #181
82tarecaro's Avatar
It also might not have the same torque capacity as the V8 T5.
Old Aug 10, 2012 | 03:44 PM
  #182
chazman's Avatar
Axle/Gears: BW 3.45
14 spline input vs 26 spline for the V8 T5. It'll fit with a 14 spline clutch. All of the NWC T5s have the same torque rating of around 260 ft lbs.
I got it cheap enough so if it's junk, it'll make an interesting door stop.
Old Aug 10, 2012 | 03:46 PM
  #183
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
He did his research and no they are not the same, see below.
V8 T5s have a 26 spline shaft, V6 and 4cyl units have a 14 spline count. You can get a clutch disc from advance adapters that is the right diameter for the 10.5" diameter V8 clutch but with the 14 spline sprung hub. Nothing exotic here guys, I ran a trans identical to this in my 91 TA for 3 years. The lower 1st gear worked perfectly with my 2.73 posi rear.
Of course it doesnt, it's not a world class unit and it's got a numerically higher gear ratio in 1st. He's running it on street tires behind a 165hp LU5, it will be fine. I had an identical trans behind my 230hp LB9 and it held up just fine. This really is the ideal swap for a lower powered car with a tall rear gear.
Old Aug 10, 2012 | 03:53 PM
  #184
Car: 1991 Camaro RS
oh yup look at all the info coming out of the wood work
Old Aug 10, 2012 | 04:05 PM
  #185
yaj15's Avatar
Car: 1988 IROC-Z
If you keep the same gear ratio that you have now with the lower geared T5 your performance should will be good.
What about the rear? Did your car come with disk brakes?
Old Aug 10, 2012 | 04:31 PM
  #186
chazman's Avatar
Axle/Gears: BW 3.45
I guess one good thing about being bolted up to an Iron Duke is that theoretically the motor might have been kind to the trans. I suspect that this trans might have been apart sometime, based on the sloppy gasket sealer on the front of it.
Old Aug 10, 2012 | 04:35 PM
  #187
chazman's Avatar
Axle/Gears: BW 3.45
Yup.
Old Aug 10, 2012 | 05:07 PM
  #188
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
I noticed that too. I've got a 3.76 geared T5 from an S10 in the basement at home. Now that you have an F-body box, even if the guts are bad, we can swap tail housings if we need to and convert it to an F-body box. The trans I have worked nicely when pulled as far as I know.
Old Aug 10, 2012 | 05:36 PM
  #189
chazman's Avatar
Axle/Gears: BW 3.45
Well, everything spins in all of the gears. I suppose that's a good thing. I marked the input and tailshafts and confirmed the 1st gear ratio too.
Old Aug 13, 2012 | 03:42 PM
  #190
yaj15's Avatar
Car: 1988 IROC-Z
What is the story with the GM T-5's and their gear ratios?
I have heard that the G92 cars and non-G92 equipped cars with the T-5's had different gear ratios. I looked up the information on this link to see if I could find out what gear ratios went in the T-5 depending upon the options that the car had.
https://www.thirdgen.org/calculations
I've read in some magazine articles that the G92 equipped thirdgens were supposed to have the T-5 with the 2.95 first gear and the 0.73 fifth gear. I'm assuming that these gear ratios would have been paired with 3.42 or 3.45 rear axle gears.
I've also seen some TPI cars that claimed to have the T-5 with the 2.75 first gear and 0.63 fifth gear. I'm guessing this set up would have been paired with 3.08 rear axle gears for cars that were non-G92 spec.
For the T-5 V8 cars the 2nd-4th gears seem to be 1.94, 1.34, 1.00 respectively.
Hopefully I'm writing down the right information on here. Please correct me if I am wrong.
I just didn't know that so many gear ratio combinations were available for the T-5 between the V8 and V6 cars. Sounds like each application that GM used the T-5 in they produced a lot of diffrent gear ratios for each application.
Old Aug 13, 2012 | 05:14 PM
  #191
chazman's Avatar
Axle/Gears: BW 3.45
The 2.75 1st gear ratio that many places report appears to be bogus. They were all 2.95.
Old Aug 13, 2012 | 05:21 PM
  #192
yaj15's Avatar
Car: 1988 IROC-Z
Ahh I see. What about the 0.63 vs. 0.73 overdrive ratio gear?
Old Aug 13, 2012 | 05:40 PM
  #193
chazman's Avatar
Axle/Gears: BW 3.45
During '89-'92 both were offered. The .63 was the standard ratio and was ID'd on the SPID as M39 with the 3.08 rears, and the 73, ID'd as MK VI was combined with the 3.45/3.42 gears.
Old Aug 13, 2012 | 05:50 PM
  #194
yaj15's Avatar
Car: 1988 IROC-Z
Thanks for the info. I'm learning a lot about the T-5 on this thread. I've always been more intrested in the 700r4 so I know a lot more about them and making them perform better than the T-5.
Old Aug 14, 2012 | 11:44 AM
  #195
chazman's Avatar
Axle/Gears: BW 3.45
I have noticed that the CFI really likes the cooler weather. Or should I say, it really hated the brutal 90-100 degree weather we went through recently. Runs smoother, better throttle response now, the exhaust even sounds different.
I wonder if 100* heat has an effect on the CFI's fuel distribution more than other systems.
Old Aug 14, 2012 | 04:26 PM
  #196
yaj15's Avatar
Car: 1988 IROC-Z
Dosen't your car have the flaps that open up on the hood when you accelerate hard? When the flaps are closed where is most of the incoming air coming from?
Even when the air is warmer you would have an advantage with those flaps when they open (in terms of cooler incoming air) because its not heat soaked with warm air from the engine compartment. This the same ram air effect that the TPI camaro cars enjoy with the inlet air coming in behind the fog lights at the front of the car.
I have a neighbor that has an early 80's corvette (I forget the exact year I think its a 1982 model though) but he has the cross-fire 350. The area that I live in is in the central valley in northern California. For the past week it has been 105 - 110 degrees or higher in some locations that are further away from the coast.
When the temps get that hot he said his car was more 'tempermental' than when the ambient air temperature was cooler say less than 75 - 80 degrees. His car would not idle correctly and the power delivery as you accelerated would not be as linear, smooth, or even keeled as when the temperature was lower. We also don't have the humidity issue to deal with like guys in the midwest, east coast or the south during summer time. My neighbors car is an all stock 350 crossfire. The only modification that he has done was install a catback exhaust some time ago.
Some of these engine characteristic issues also may be due to different computer tunning as well. Is there significant difference with respect to hardware and computing power between a cross-fire injected car and a L03 305 TBI car from '88-'92? The cross-fire injection set up contains 2 TBI units on a cross ram style manifold. The later TBI 305 and 350 engines just had 1 single TBI unit on a non-cross-ram style intake manifold.
I know with the TPI cars the ECM was upgraded from the original 1985 setup. I'm wondering if the later single unit TBI 305's and 350's also got upgraded ECM's or PROM's with respect to the earlier cross-fire injected 305 and 350 engines?
Old Aug 14, 2012 | 06:44 PM
  #197
chazman's Avatar
Axle/Gears: BW 3.45
Honestly, the only time my butt dyno can feel afew more horsies, is when those hood flaps open on a really cool evening. On those evenings, the intake sound also pretty well mimics the sound we got when we used to flip our air cleaner lids over back in the day.
Old Aug 14, 2012 | 06:50 PM
  #198
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
When the temps were above 90 degrees last month I was having vapor lock issues with the CFI on my '82 Recaro T/A. The fuel would vaporize between the front and rear throttle bodies making the rear TBI have little or no fuel spray from the injector. A minute or two of cranking the engine would pulse the injector enough to purge the line.
Old Aug 14, 2012 | 11:04 PM
  #199
yaj15's Avatar
Car: 1988 IROC-Z
Hmm, thats very intresting. Well ha ha sounds like we have found another topic to dig in to.
When you get your 5-speed trans swapped in let us know how the car runs. For the LB9/T-5 cars I thought they got a different PROM from the factory with respect to LB9/700r4 cars.
With my own car I have the L98/700r4 combination. I haven't noticed a real difference in performance when the weather gets hot. When the weather is cold (around 55 degrees or lower) in the winter time that cold air helps the engine perform better. It's not a big difference but there seems to be a little more power across the rev range and throttle response improved a little.
I've got Hawks Thirdgen ram air TPI boxes and a gutted TPI air lower air filter now. I installed that in the car in June and it improved the breathing from idle to redline. I'm curious to see if there is a performance improvement when the weather starts getting cooler again.
Old Aug 16, 2012 | 01:10 PM
  #200
yaj15's Avatar
Car: 1988 IROC-Z
This is a video I found for a 1983 Z28 LU5 Cross-Fire for sale. Around time indexes 7:25 & 7:52 in the video the driver gets on the gas hard and you can see the hood flaps open up.
Is it true that GM had a lot of issues with the LU5? In one of the Camaro books that I have I read that LU5's left some owners stranded when they drove in the rain because those flaps let water in to the engine. I thought that flap intake system was sealed to the outside environment so that only air could make its way in to the engine?
