RPO code help
Old Mar 27, 2012 | 04:42 PM
T/A's Avatar
T/A
Car: 1990 T/A w/WS6
Engine: 5.7L V8 TPI
Axle/Gears: 3.23 w/ posi
RPO code help
Hello, I was looking at my build sheet today, and notcied 4 RPOs that though they had a short description next to them i didn't know what they meant.
first is FE2 "susp spl perf"
and the other two are 85Q and WW6 which are both Brilliant red RPOs.
is one for the GFX and the other for the body?
also I9P which is described as "Black"
Old Mar 27, 2012 | 06:06 PM
tyler86z28's Avatar
Car: 1986 Camaro Z28
Engine: 355 4 bolt 4bbl
Transmission: T-5 manual
Axle/Gears: 3.73 posi.
Re: RPO code help
FE2 is for 30mm front sway bar, and 24mm rear sway bar.
WW6 is Brilliant red metallic Aero Pkg.
85Q is medium slate gray metallic molding colour
19P May be black interior trim...not sure.
Hope this helps...I had the same issues last week decoding my Camaro.
Old Mar 27, 2012 | 08:24 PM
T/A's Avatar
T/A
Car: 1990 T/A w/WS6
Engine: 5.7L V8 TPI
Re: RPO code help
Thanks, that helps. as for the 19P my freind hypothesized it to be the rims (in this case Pw7s) which are the only black thing on the car that Ive found.
Old Mar 27, 2012 | 09:19 PM
JT's Avatar
JT
Community Administrator
Re: RPO code help
19P is for the black PW7 wheels.
Can you post, or email me jt@thirdgen.org, your build sheet for our RPO Decoder database that we're working on?
My GM manual shows 85Q as MOLDING COLOR,MEDIUM SLATE GRAY
Old Mar 27, 2012 | 09:29 PM
T/A's Avatar
T/A
Car: 1990 T/A w/WS6
Engine: 5.7L V8 TPI
Re: RPO code help
sure, should I scan it? or just take pictures of it?
Old Mar 27, 2012 | 09:50 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: RPO code help
GM was ingenious with the RPO's for the color of "things." The first two numbers indicate the Color, and the letter the Letter designates the part:
19B = Black Cloth Standard Seats
52P = Gold Metallic Wheels (See chart Below)
Below is a listing of the third character that I have found:
A= Body Accent Stripe
B= Cloth Interior Trim
C= Cloth Interior Trim
D= Cloth Interior Trim
E= Cloth Interior Trim
F= Covering Floor Mat, Color
G= Cloth Interior Trim
H= Cloth Interior Trim
I= Interior Trim
J= Cloth Interior Trim
K=
L= lower (Secondary) Paint
M=
N= Interior Trim Combination
O=
P= Wheel Color
Q= Molding Color
R=
S=
T= T-Top Color
U= Upper (Primary) Paint
V= All Vinyl interior Trim
W= All Vinyl interior Trim
X=
Y= All Vinyl interior Trim
Z= All Vinyl interior Trim
1= Interior Trim
2= Leather with Articulating Seats
3= Leather
4= Leather
5= Leather
6= Leather
7=
8= Cloth Interior Trim
9= Seat Belts
Hope it helps.
Old Mar 27, 2012 | 09:52 PM
JT's Avatar
JT
Re: RPO code help
Either is fine as long as it's fairly legible for usage.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
