build sheet / cowl tag question plz help
Subscribe
May 20, 2012 | 12:43 AM
I found this build sheet in the drivers seat of my 84 trans am, and i have seen build sheets from other members but nothing that looks like mine
this is the only sheet i found in my car, nothing under the carpet
does anyone know anything about this different type of sheet?
and can anyone explain the very botton line on the RPO code sticker
also is there a company that can make reproduction door stickers
of the 2 on the driver door the weight tag is in very bad shape and the other one is completely gone
or for the cowl tag that would have been attached by fisher body it was gone when i got the car, or did some just not come with one.
thank you
build sheet / cowl tag question plz help-build-sheet-1.jpg   build sheet / cowl tag question plz help-rpo-codes.jpg
Reply 0
May 20, 2012 | 01:41 AM
Re: build sheet / cowl tag question plz help
What you have is a trim sheet. Trim sheets aren't the same as a build sheet as they don't have all the RPO codes and other information that a master build sheet would have. There are multiple trim sheets involved.
As far as the bottom line of the RPO sticker, that's the paint color information. You have a black (upper and lower), water-based paint, Trans Am.
Reply 0
May 20, 2012 | 09:30 AM
thank you
Reply 0
May 20, 2012 | 11:54 AM
Check under the rear seat bottoms. Thats where I found the actual build sheet on my Van Nuys, CA built '84 T/A.
My car was made about 4,000 units before yours.
Reply 0
Subscribe
