interior strip
Car: pontiac firebird trans am 1984
Engine: 5.0 v8 H.O
Transmission: auto
Axle/Gears: 700R4 auto overdrive
interior strip
hi i know it mite be a dumb question but how do you strip the interior down thanks
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: interior strip
Start with the screws and keep going.Make sure you separate them by each part your removing,ex.baggies would work well.just mark the bags.
Car: 1987 TA GTA, 1987 IROC 1988 Formula
Engine: 350 tpi/305 tpi/350 tbi
Transmission: All have 700r4's
Axle/Gears: 10 bolt with 3:73's
Re: interior strip
Its pretty easy, you will need a trim poppper for the door panels make sure like mantaguy said bag all of it and label the bags!!
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
Re: interior strip
seat belt bolts should soak in some pentrating oil after the carpets out if you have ugly floors, even if you dont. and yeah labeling is important eventually youll become a champ at it after awhile and just remember
Re: interior strip
Start at the back and move forward, this will be the easiest way to get everything out. Seat belts are a T-47 torx, if you use a T-45 you are much more likely to strip the bolts out.
