87 TRANS AM
87 TRANS AM
i have purchased a trans am that is supposed to be called a california addition. i was told that there where a certain number of these cars made. the car is an 87 but looks like a 84. t-tops and 5.0 H.0. 5 speed. it also has the the induction hood on it as well. i have a vin # that is all over the place when i decode it. VIN#1G2AW8772DL228780 and was built in Van Nuys plant..what have i got here anyone know. speedo is all in miles and the car has no airconditioning
Re: 87 TRANS AM
Based on the VIN, you have a 1983 Trans Am. The 10th digit is D for 1983 and the 5th digit is W for Trans Am. It's not a 1987.
However, it looks like you have a mistake in your VIN as it's not showing valid. Despite this, just based on the first part of the VIN, it's not a 1987 for sure unless you have the wrong VIN.
Re: 87 TRANS AM
i have the build sheet for the car and reads the same as the dash sticker..i can send a pic of it if it helps any to who can figure this out
Re: 87 TRANS AM
You can post a picture of the build sheet if you'd like.
The VIN you provided is for a 1983 Trans Am. A 1987 Trans Am would start out with a 1G2FW. Your VIN starts out with 1G2AW. You have a D in the 10th digit, which is for 1983. A 1987 VIN would have an H as the 10th digit.
Based on the VIN you provided, it's a 1983 Trans Am and not close to a 1987 Trans Am.
If it's titled as a 1987, it's either an error or the VIN doesn't match.
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Re: 87 TRANS AM
I was at a garage sale last spring down the street from my mom's house and there was a 3rd gen TA under a cover. The lady said was a California addition and it's rare. I do know the car is still under the cover and I have never see out out of the garage. I forget what it looked like as she did not remove the cover all the way. I want to say she said it's an 87 as well.
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
