Has this firebird had a ttop roof added?
Old Oct 17, 2012 | 04:12 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
the keys dont match for the ttops and theres a good amount of rust.
Old Oct 17, 2012 | 04:39 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
Re: Has this firebird had a ttop roof added?
added? To me it just seems like the old owner just lost the original t-tops so re replaced them with other t-tops.
Old Oct 17, 2012 | 04:54 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
And they may not have fit right and leaked. Things don't take long to rust.
Old Oct 18, 2012 | 08:13 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Looks factory, but the part that really tells you is the roof bar. It's obviously added in on conversion cars.
Lot of rust on that roof. I would take a look inside the b pillars before I put any work into that body.
Old Oct 18, 2012 | 09:43 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It looks like the original t-tops leaked for a long time.
Old Oct 18, 2012 | 03:00 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
just making sure that seam was factory before i started any rust removal, thanks. i didnt want it to be a hartop conversion
Old Oct 19, 2012 | 08:29 AM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
looks stokc to me and like was said maybe the tops were replaced.
Old Oct 19, 2012 | 02:42 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
I'm going to take a shot in the dark and ask the obvious question -- do you still have your RPO label in the center console? If you do, and you see "CC1" on there, then it's an original t-top car.
Old Oct 19, 2012 | 03:02 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
ouch. show us the progress.
Old Oct 22, 2012 | 06:53 PM
sloick's Avatar
Car: Many
Engine: Several
Transmission: Automatics
it looks like someone has cut the roof off the car and added a t top roof to it. i cant remember GM ever using those little button head screws.
Old Oct 25, 2012 | 09:45 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Easy way to tell. Look at the "A" pillar, measure the width of the painted area between the windshield and Door window, then measure the painted area between the windshield and T-top... If the measurement is about the same for both the Door Window to Windshield is to Windshield to T-tops then it is Factory. BUT if the measurement of the T-tops to windshield is about twice the distance of the Door window to Windshield then it is C&C.
colton_carlson
Mar 8, 2019 12:21 PM
deracer
Apr 11, 2016 12:04 AM
gta power
Convertibles
Sep 23, 2015 09:32 AM
E_S
Aug 29, 2015 04:09 AM
snakeshooter
Aug 22, 2015 07:06 AM
