Questions about a 87 Camaro
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Re: Questions about a 87 Camaro
Run the VIN through a VIN decoder. Easiest way.
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Also post some pix and we might be able to give you a good idea what it is.
Check your SPID's RPOs in the center console if they are still there then look them up to see what you have. Specific combinations were available on certain models. From this information you start to break it down as to what your 87 is. If that is missing post a picture and let us try to figure it out.
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Car: 1987 TA GTA, 1987 IROC 1988 Formula
Engine: 350 tpi/305 tpi/350 tbi
Transmission: All have 700r4's
Axle/Gears: 10 bolt with 3:73's
Probably a sport coupe if your having trouble figuring out what model it is. A Z28 or IROC-Z is easy to spot.
Engine: LS1, LB9, L03
Post your VIN (or at least the first 8 digits if you're worried about privacy). We can rule a few things out just based on what engine it originally had.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
