82 z28 information
Car: 82 Z/28
Engine: 5.0
Axle/Gears: 323
82 z28 information
I have an 82 obviously and the more i read on here the more i realize that it seems like they had a lot of year specific parts and alot of carried on parts. So here is what im asking can you tell me about your personal experience not from reading different forums and what not ide like this to help my self and others new to 82 and maybe even do one for every year. Pictures would be very nice as well
Kenneth
Kenneth
Car: 1982 Camaro Pace Car
Engine: LU5 Crossfire
Re: 82 z28 information
Are you asking what is different between an 82/83 Z28 and later models? Some things I can think of right off the top of my head are:
I'm sure there are a lot more mechanical things I'm not remembering.
What's a bummer for anyone trying to make an 82 correct is that most of the 82/83 specific stuff is not reproduced in the aftermarket because the original parts were ultimately superseded by the newer part numbers.
Things like the 82 bumper emblem without the Chevy bowtie aren't available and most places list the one with the bowtie as "correct" for 82, which isn't the case.
- Kick plates
- Seat belt retractors (roof vs. sill mount, which is why the kick plates are different than later years)
- SMC hood on Z28s (82 only)
- Dash pad ("flat" front edge vs newer chiseled edge)
- Hatch release switch is a rocker switch vs. slide switch
- Hook style t-top latches vs. 84+ pin-style
- Catalytic converter air pipe
- Z28 emblem on rear bumper does not have Chevy bowtie
- Rear storage container cover missing "grid" inserts from vents (not sure how else to describe this)
- Windshield washer reservoir
- Power window switch - same switch as later models, 82 has UP/DN lettering vs the window icon on later switches
- Exhaust - original exhaust has two resonators with a pipe between them - not sure when this was changed but think it was 82/83 only.
Car: 82 Z/28
Engine: 5.0
Axle/Gears: 323
That's very helpful thank you for the information. Funny thing I actually just called year one about a rear emblem and the guy had no clue about the lack of the bowtie as for the exhaust what do you mean about the pipe between the resonators?
The 82 used two resonators (mufflers) with a pipe between them. Here's a pic from a fellow TGO members site who restored his:
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
a few '82 only details i can think of:
-A/C hoses go over engine instead of radiator
-million mile odo
-8-track cartridge player avalible
-last install of super T-10 4spd(also last "old skool"heavy duty stick tranny)
-blue-painted engine
-"real"leather steering wheel and shift ball covering?-seems later is different material?(not totally sure on this)
-million mile odo
Car: 82 Z/28
Engine: 5.0
Axle/Gears: 323
Anybody have a clue why that did the exhaust the way they did? And why the odometer was a million miles and other years didn't have that?
The Crossfire injection set up was supposed to be a nod to the old 69 Z28 cross ram set up, so perhaps the use of two resonators was was a similar attempt to pay homage to a true dual exhaust set up.
The cynic in me says that after 82, GM realized the cars were going to last no where near a million miles so they changed the odometer.
Seriously, my opinion is that it was likely a cost cutting measure. One less tumbler saved a few cents per car. I did a quick search and found that the 1988 federal regulations stated that odometers only had to read up to 99,999 miles traveled. I didn't dig any further to see if this was in effect sooner, but I'd bet it was. If that's the case, the extra digit would not have been legally necessary so GM probably changed their design to meet the minimum federal requirement and to save a couple bucks. Just a guess.
Seriously, my opinion is that it was likely a cost cutting measure. One less tumbler saved a few cents per car. I did a quick search and found that the 1988 federal regulations stated that odometers only had to read up to 99,999 miles traveled. I didn't dig any further to see if this was in effect sooner, but I'd bet it was. If that's the case, the extra digit would not have been legally necessary so GM probably changed their design to meet the minimum federal requirement and to save a couple bucks. Just a guess. Trending Topics
The SMC hood was also available on the 83 cars as was the flat front dash pad. The troop latch style changed a couple times over the entire third gen years. I'm assuming that most of what listed above for 82 should also include 83.
Car: 1984 Trans Am- L69, WS6, J65, W62
Engine: 350 .020 over
Transmission: auto 700R4
Axle/Gears: 4.11 Limited Slip
the early 82s for both camaro and bird had emblems covering the window crank hole in the door panels on cars with power windows.
Car: 82 Z/28
Engine: 5.0
Axle/Gears: 323
yes that is my understanding i have seen 82s both with and without the emblems but never for 83 and up. this applies to both camaro and bird, then it was either sometime in 83 or 84 that started the map pocket in that spot for power window cars, my 84 had them
I always wondered about the manual window crank plug. My car was built in April of 82 and has the logo'd ones. I've seen both logo'd and blank plugs on the '82s and figured it was a mid-year change over.
Car: '82 z28
Engine: L83 5.7
I've noticed it seems certain '82 z28s and trans ams had aluminum core radiator while most had copper/brass radiator;my 3/82 built LG4/4spd had copper/brass,while a loaded CFI 4/82 TA i saw had an aluminum core radiator that looked original.A 7/82 CFI z28 i saw had copper/brass that looked original.
Car: 82 Z/28
Engine: 5.0
Axle/Gears: 323
How would you go about finding out about the radiator? And now that I think about it I saw a picture of an 82 that had window cranks on the door but power window controls in the center console something was obviously off there
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
rb85TA
26
Sep 14, 2015 10:29 PM
Street Lethal
Sep 7, 2015 01:09 PM
