How can I tell?
Car: 1985 TA
Engine: L69 305 H.O.
How can I tell?
I have a 1992 Camaro Z28 that I purchased when I was stationed in Hawaii and ended up shipping it back to the states. I recently started thinking about selling it as I have a 60+ mile daily commute and have put less than 3000 miles on it in the last 6 years or so. In preparation to selling it, I got an Autocheck report and found out that this car is listed as having been a police use vehicle. Having read a bit about B4C cars, I went through the vehicle, but am unable to find an RPO sticker, so I'd like to ask how can I tell *IF* this is an actual B4C car? Thanks in advance!
Re: How can I tell?
If the SPID is not located on the backside of the locking luggage compartment in the driver's back section (in the hatchback section), then go to Compnine.com, sign up for a free account and then supply your VIN. You should see all RPOs for that VIN.
Car: 1985 TA
Re: How can I tell?
Thanks for your reply. I went to compnine and put in my VIN and it tells me: Vehicle: CAMARO RS 2 DR, even though it then lists the Z28 option. I did not see 1LE or B4C in the codes from them, so this must not have been a special order even though it was police use vehicle. I always kind of wondered why it had no Z28 badges on the outside, guess they removed them.
Engine: LS1, LB9, L03
Re: How can I tell?
Could have also been a drug seizure or similar car, frequently police departments will register and use the cars they've seized, particularly if it's something sporty.
Car: 1985 TA
Re: How can I tell?
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: How can I tell?
The big question is does it have the big brakes in the front (12 inch rotors) or just the standard 10.5. That will tell you if it was a B4C.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: How can I tell?
the B4C cars did not have the big spoiler, the hood blisters or T-tops. That does not mean it could not have been a Police use vehicle, it just means that it was not ordered as a B4C...
