help...rpo code sticke torn off
Old Mar 17, 2014 | 12:01 PM
84z5350's Avatar
Car: 1986 z28
Axle/Gears: ?
just talked to my local dealership about running the vin number to track down the rpo list and I was told that they can't do anything older than a 1990...
I am hoping that some one on here knows some magical way of getting this information.if I post my vin can someone help me??
my car is a 1986 z28
Old Mar 17, 2014 | 01:19 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: help...rpo code sticke torn off
I heard that cars older than '77 were the issue, not 1990. That sounds really early to cut off that kind of info, have you tried a different dealer? Perhaps an out of state one?
Some other ideas that come to mind would be to check behind your door panels, under the carpet (front and rear) and see if you have a build sheet hiding in there somewhere. Also your cowl tag could tell you RPO information if your car was built while they were still putting those on (it would be located on your core support under the hood).
Old Mar 17, 2014 | 10:25 PM
David M's Avatar
Car: '84 Z28
Engine: L69
A different dealer will tell him the same thing. The GM EPC (Electronic Parts Catalog) only goes back to 1990 for U.S. built cars and trucks. Canadian vehicles go back to 1980.
Old Mar 18, 2014 | 07:12 AM
Car: 1983 Z28
Ah.
My email says that JT responded to this but I don't see his post anywhere...kindof confusing. idk if the OP saw this but this website can get you the info you need (totally taking this from the email that was generated by JT's mystery post...not my personal knowledge).
http://www.gmmediaarchive.com/
Old Mar 20, 2014 | 08:39 AM
84z5350's Avatar
Car: 1986 z28
Axle/Gears: ?
I did also receive jt's mystery email.
thank you for the help and info I'll give it a try
Old Mar 22, 2014 | 09:28 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
youre screwed,, I have the same car.same problem. no RPO sticker in the console.and since the car was re painted previous to my purchase. no door sticker either. so it appears owners such as us have no way to know jack about what we now own
Old Mar 22, 2014 | 09:47 AM
84z5350's Avatar
Car: 1986 z28
Axle/Gears: ?
it definitely sucks
BumpaD82
Feb 26, 2016 02:57 PM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
anesthes
Sep 18, 2015 12:34 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
SlowAZ28
Sep 2, 2015 05:19 AM
