The attached picture is the best I have found. I can't make out what it says exactly and I'm sure the rears would have been the same and the fronts the same.
Anyone have any better images? I'm trying to get a set reproduced by a local sign shop who is also reproducing a dozen other decals from my 92 GTA, everything from my air bag warning label on the headliner, the decals on the upper radiator mount, to the decal on my original AC compressor.
So, who's got better pics and info on these than me
Also where to buy grey valve stem caps would be appreciated!
Quote:
Hey, any help is help. Thanks for zooming in, I don't have any good photo software myself.Originally Posted by Joe Tag
Not a whole lot of help, but I see 1007431? ??0 zoomed in as tight as the resolution will allow. No software just zoom on windows and a few other tricks in paint on a 32" monitor LOL. I think the 1 I posted at first is a 7 then maybe an 8? ie; 10074378 ??0
They may not be exactly the style you're looking for, but I've seen gray valve stem caps at Autozone.
Not sure what the pupose of the wheel stickers are, but they would certainly be peeled off during PDI. Not sure why you would want them unless the car has zero miles. It's not like they make the wheel look any better.
gt4373
close
- Join DateNov 2011
- LocationCT
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car1984 Chevrolet Camaro Z28
- Engine5.0 Liter 4-BBL V8 High Output
- Transmission5-Speed Manual
- Axle/Gears3.73
- Liked:356 Times in 205 Posts
These Would Be Most Likely Removed By The Dealer During Dealer Prep Before Delivery.
I see 1007431R XND
I love the captcha game.
I got pictures of them and had them reproduced for my TTA. its the front and rear wheel part numbers plus the RPO code for them on there. When I'm on my other computer I'll post pictures of them and the size as well.
I had pretty much every decal/sticker reproduced when I restored mine; took years to collect all the info needed along with good photos and accurate size etc.
Ok so the sticker is exactly 2 inches wide by 3/8's inch tall. It has a low gloss sheen to it both the white background and lettering.
Front: 10074316 XNB
Rear: 10074318 XND
XNB and XND you find on the build sheet (or whatever style wheel they should put on there).
So the above is for the gold 16" GTA/TTA wheels ...
Hope this helps.
Front: 10074316 XNB
Rear: 10074318 XND
Hope this helps.
For the valve stem caps these are the ones I managed to get hold of after some time searching for them ...
Original GM on the right (used) and a new as close I could find new replacement on the left.
Thank you VERY much for sharing! I really appreciate it!
Alex
Alex
TTOP350
close
- Join DateOct 2001
- LocationIl
- iTrader Positive Feedback100
- iTrader Feedback Score(9)
- Car1989-92 FORMULA350 305 92 Hawkclone
- Engine4++,350 & 305 CIs
- Transmission700R4 4800 vig 18th700R4 t56 ZF6 T5
- Axle/Gears3.70 9"ford alum chunk,dana44,9bolt
- Liked:1,157 Times in 756 Posts
Here is the decal I have from my NOS set of Black crosslace wheels. ( I still have it)
