Instrument panel question
I just got an 82 sport coupe, factory 305 car. The gauge cluster has no tach. Has speed/kilo's on left and gallons/liters on the right gauge. And three warning lights in the center. Does anyone know if this is year and model correct?
Car: 1991 Firebird Formula
Engine: 5.7L TPI
Re: Instrument panel question
I assume this is for a Camaro, what trim level is it? The lower trim levels on Camaro/Firebird often omitted the tach and other guages.
Engine: LS1, LB9, L03
Idiot lights and no tach are standard. Very few base Sport Coupes were optioned with U21 Special Instrumentation, which was standard on Berlinettas and Z28s.
U21 included a tach, volt meter, oil psi gauge, temp gauge, and trip odometer.
Car: 1982 MSE, 1988 S10 Blazer
Engine: 305 in both!
Transmission: 200c / Th700r4
Axle/Gears: 3:73 / 3.42
At one time I owned a plain jane v6 firebird with the idiot lights and no gauges. I prefer all the gauges myself to keep an eye on things.
Car: 88 GTA Notchback
Axle/Gears: don't know
I owned an 85 305 car with the idiot light dash long ago. IF I remember right, all you have to do is swap the gauges (obviously) and the corresponding switches to the correct sensors. Should be fairly plug n play IIRC.
Ghettobird52
Jul 5, 2024 11:18 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
