RPO code dissection....
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
here is the RPO code for a potential car purchase... according to him its a 1991 Pontiac Firebird Formula V.I.N : 1G2FS238XML244796
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: RPO code dissection....
Vehicle:
FIREBIRD 2 DR
Year:
1991
Build Date:
1991-05-02
Found 47,612 vehicles matching that year and model in our database.
RPO Description Matches
AH3 ADJUSTER,SEAT,4-WAY MANUAL,DRIVER 4-WAY MAN D/SEAT ADJR(AH3) 13,751
AJ3 RESTRAINT SYSTEM,FRONT SEAT INFLATABLE DRIVER SI INFL RST SYS(AJ3) 47,612
AN4 RESTRAINT PROVISIONS,CHILD(CANADIAN) CHILD RST PROVISIONS(AN4)(CANADIAN) 1,498
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9) 44,743
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3) 41,671
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31) 41,671
A90 LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90) 28,389
BC8 ORNAMENTATION,INTERIOR,FRONT DOOR MAP POCKET RH AND LH DR MAP PKT(BC8) 41,671
B2L ENGINE PACKAGE-V8 5.7L, PFI ENG PKG(B2L) 3,489
B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING(USED WITH APPEARANCE PACKAGE Z12) BODY SI MLDG(B84) 46,790
C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49) 33,076
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60) 46,946
DC4 MIRROR,INSIDE,REARVIEW TILT,DUAL READING LAMP I/S DUAL READING LP RR VIEW MIR(DC4) 46,761
DG7 MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL,ELECTRIC(PAINTED)(USED WITH SE Z7M,STE Z7N,LE Z7K) O/S ELEC R/CON PAINTED MIR(DG7) 27,108
D42 COVER,REAR COMPARTMENT SECURITY(SHADE) R/CMPT SECURITY SHADE(D42) 25,346
D5X GEAR-SPEEDO DRIVEN (D5X) 3,489
D8I SENSOR-VEH SPD (10456089) (D8I) 2,268
D81 SPOILER,REAR,AERO WING RR AERO WING SPLR(D81) 13,733
E5Z ADAPTER - SPEEDO - DELETE 47,612
E9Z KEY - SPEEDO - DELETE 47,612
FE2 SUSPENSION SYSTEM, HANDLING(USED WITH PERFORMANCE PACKAGE WS6) (FE2) 10,360
GU5 AXLE,REAR,3.23 RATIO 3.23R(GU5) 26,461
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80) 9,171
IPC TRIM,INTERIOR DESIGN (IPC) 44,743
J42 BRAKE SYSTEM,DRUM(ALUMINUM) AL BRK SYS(J42) 2,957
KC4 COOLING SYSTEM,ENGINE OIL (KC4) 4,569
K05 HEATER,ENGINE BLOCK(CANADIAN) ENG BLK HTR(K05)(CANADIAN) 1,498
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34) 30,237
K68 GENERATOR,105 AMPERE 105 AMP(K68) 8,835
L98 ENGINE, 5.7L, (5.7-8) 350 CID, V8, TPI 5.7-8(L98) 3,489
MD8 TRANSMISSION,AUTOMATIC 4-SPEED(THM700R4/4L60) 4-SPD A/TRANS(MD8) 43,399
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE PROVISIONS(MX0) 43,399
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5) 43,196
N10 EXHAUST SYSTEM,DUAL(USED WITH TOURING YP6) D/EXH(N10) 4,569
N36 STEERING WHEEL,SPORT-4 SPOKES SPORT STRG WHL(N36) 41,430
N64 WHEEL AND TIRE,SPACE SAVER SPARE(ALUMINUM) STOWAWAY SPARE(ALUM)(N64) 7,327
PE0 WHEEL,16X8,ALUMINUM,LIGHT WEIGHT STYLED LGT WT AL WHL(PE0) 5,382
QLC TIRE,ALL P245/50ZR16/N BL R/PE ST TL HWY TIRE(QLC) 10,360
R7G CONTROL - SALES ITEM NO. 32 556
T61 LIGHTING,DAYTIME RUNNING DAYTIME RUNNING LGT(T61) 1,498
UB3 CLUSTER,INSTRUMENT GA(UB3) 47,612
UQ1 RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1) 47,612
UX1 RADIO,AM/FM STEREO,WEATHER,CASSETTE,EQUALIZER,ETR (UX1) 28,268
U19 SPEEDOMETER,INSTRUMENT,KILOMETERS PER HOUR KPH SPEEDO(U19) 3,724
U62 SPEAKER SYSTEM,4,DUAL COAX FRONT,DUAL COAX PACKAGE SHELF 4 SPKR SYS(U62) 47,612
U75 ANTENNA,POWER(CHROME) PWR ANT(EXPORT)(U75) 18,779
VAN PLANT CODE VAN NUYS, CA, CPC VAN NUYS,CA PLANT CODE(VAN) 47,612
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3) 37,477
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73) 44,388
WS6 PERFORMANCE PACKAGE,SPECIAL(MERCHANDISING OPTION) SPECIAL PERFORMANCE PKG(WS6) 10,360
W66 FORMULA OPTION(MERCHANDISING OPTION) FORMULA(W66) 5,464
Z31 IDENTIFICATION - PRICE SHEET ADVANCE 1,497
Z49 MANDATORY CANADIAN BASE EQUIPMENT MODIFICATIONS(CANADIAN) CANADIAN(Z49) 1,498
1SB PACKAGE-OPTION 02 (1SB) 19,280
15P WHEEL COLOR,MEDIUM SLATE GRAY (15P) 5,382
19C TRIM COMBINATION,CLOTH,BLACK (19C) 7,941
19I INTERIOR TRIM COLOR (19I) 8,499
199 SEAT BELTS COLOR BLACK (19) (199) 8,499
24Q MOLDING COLOR,BRIGHT BLUE METALLIC (24Q) 3,023
6ZW SPRING COMPTR SELECT FRT LH SUSP(6ZW) 7,587
7ZW SPRING COMPTR SELECT FRT RH SUSP(7ZW) 7,587
8NL SPRING-COMPTR SELECT RR LH SUSP(8NL) 11,102
9NL SPRING-COMPTR SELECT RR RH SUSP(9NL) 11,102
98U EXTERIOR COLOR,PRIMARY, DARK BLUE METALLIC (98U) 3,092
Car: 1984 Trans Am
Engine: 305... going LSX
Transmission: T-5... going T-56
Can somebody help dissect mine, please?
I'm very familiar with 4th-gens, but this is the first third-gen I've owned. Where exactly is the RPO decal located in the '84 model year T/A?
Thanks in advance for the help!
VIN: 1G2AW87H2EL243123
The SPID started appearing around 1984 so you may or may not have one. If you do, it's located on the inside wall of the center console storage.
If it's not there, about your only option is finding a buildsheet in the car or going to PHS and order an invoice - but it won't have all RPO codes.
Compnine.com, which is what okfoz used for the post above, does not have records for any ThirdGen older than about 1990 unless it's a Canadian export.
Car: 1984 Trans Am
Engine: V8 305
sweet thanks.. for this car in a dealership and he wants 6k for it.
