DIAMOND SPOKE WHEEL COLOR CODE
Old Apr 4, 2015 | 08:33 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Does anyone know the color code used for the gold diamond spoke wheels (PW7) found on my 1991 Trans Am? I would like to strip and refinish the wheels but have not been able to find the correct paint code.
Old Apr 5, 2015 | 03:07 PM
AmorgetRS's Avatar
Re: DIAMOND SPOKE WHEEL COLOR CODE
Here you go:
https://www.thirdgen.org/forums/hist...eel-color.html
Old Apr 5, 2015 | 06:51 PM
tavert91's Avatar
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Thank you very much. I tried searches but got nothing useful. Probably a skill area I need to work on!
Old Apr 5, 2015 | 07:18 PM
gearheadotaku's Avatar
Car: '91 Firebird
Engine: 305 TBI w/LT1 cam
Transmission: T5 swapped in
Axle/Gears: 9 bolt 3.27 w/discs
now if I could get the charcol color code...
Old Apr 15, 2015 | 02:21 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The Charcoal color is the same color they used on the lower stripe of the Yellow and White Formulas from 1987-1990...
I believe this is the correct color: Gunmetal Metallic 7782 Color number 84 for 1987...
okfoz's Avatar
It is not cheap paint, it has pearl in it... I painted my ROH wheels with it and it looks killer IMHO
Old Apr 16, 2015 | 02:31 AM
FrankieRider2's Avatar
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
www.autocolorlibrary.com has images of the actual PPG GM paint charts by year, but the wheel paint charts that my PPG store used to have are not there.
Depending on the build date, if the color is Gunmetal it could be listed as either 84P or 87P; the color code charged partway through the '87 model year, although the actual color did not.
Old Apr 16, 2015 | 07:35 AM
okfoz's Avatar
Thanks Frankie... I noticed that the 7782 was changed from 84 to 87... I had noted somewhere it had changed in the 1988 Model Year... I did not know it was a mid year change... I will have to look and see if any of my 87's have the 87
lee01
Apr 9, 2016 01:56 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
LT1Formula
Aug 20, 2015 09:36 PM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
