1987 GTA steering wheel
Old Apr 22, 2015 | 04:49 AM
pawcio's Avatar
Car: GTA 89
Transmission: TH700
Axle/Gears: BW 9 bolt
Hello
I have two questions about 87 GTA which I have found to buy.
1. Is this possible that 87 GTA comes with factory steering wheel with radio buttons?
2. The decals below door locks are standard for GTA?
thx
Old Apr 22, 2015 | 11:41 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: 1987 GTA steering wheel
The radio controls were introduced in 1988... never seen an 87... It would be possible to install the steering wheel control system, not sure how much work it would be, but it would not be impossible.
The original wheel was the "Formula" Steering wheel but with the GTA embossed (IIRC) emblem in the center. The Firebird, Formula, Trans Am all got the embossed bird IIRC, been a while since I have looked at my original wheel.
There were no emblems on the doors below the door locks.
John
Old Apr 22, 2015 | 06:06 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Yes, 1987 should not have radio control wheel. Proper 1987 wheel looks like this:
Old Apr 24, 2015 | 02:58 AM
FrankieRider2's Avatar
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
There is no mention of this option in any '87 literature I have for the Firebird. It was available on the Bonneville and, IIRC, 6000 models.
Never seen an '87 with the controls. The steering wheel for '87 is one of the nicer looking of the 3rd Gen era, IMO. Love the small metal GTA emblem on the horn button.
Old Apr 24, 2015 | 03:50 AM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
Does the horn work on this car? It would be interesting to pull the control pad off (attached only with velcro) and see what is behind there.
Reason I asked if the horn worked is because that would prove the wiring harness for the radio is there because the whole assembly is unique to those type of wheels.
Old Apr 24, 2015 | 09:43 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
The GTA emblem on the 1987 wheel is not metal, it is just an embossed shape molded into the rubber and painted gold. It is quite detailed, the little bird even has wisp of fiery breath.
And I agree, by far this is the nicest third gen wheel of all.
Old Apr 24, 2015 | 09:46 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Horn on radio control wheel is same as any other horn button - just a simple grounding switch. The fancy piece in this column is the turn signal switch - it has a light sensor that sends the control button signals to the radio.
Old Apr 25, 2015 | 02:58 AM
Engine: 5.7L TPI
Axle/Gears: 3.27:1
My mistake.... I had one of the '87 wheels for years and had the emblem out last fall trying to clean it and thought it was metal.
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
