fuel tank size
Old Jun 21, 2015 | 06:56 PM
Jimmy R's Avatar
Car: 1989 IROC-Z
Engine: 5.7 TPI
Transmission: 89 Corvette option tranmission
fuel tank size
Hey what the size of the fuel tank in a 1989 IROC Z my gas gauge is acting up and im tying to figure my range based on avg. observed mileage which is 16.5-17 mpg when not playing with it LOL
Old Jun 21, 2015 | 07:32 PM
Stauf's Avatar
Car: 91 Z28 Coupe
Re: fuel tank size
If it was never swapped, 15.5 gal.
Old Jun 22, 2015 | 09:33 AM
Drew's Avatar
Re: fuel tank size
Call it 14-16 gallons and you're in the ballpark. To the best of my knowledge, all the tanks 82-92 are the same physical size. The internal pump, baffling, etc displace more fuel than a car with just a sending unit and pickup, so the published capacity varies. If you look up the replacement tanks on Rock Auto, they're all listed as 14 gallons.
Of course the correct answer is to fix your gas gauge. Chances are pretty good it's the sending unit in the tank, but you'll need to troubleshoot it.
Old Jun 23, 2015 | 11:19 AM
Jimmy R's Avatar
Car: 1989 IROC-Z
Engine: 5.7 TPI
Re: fuel tank size
Yea I know but money is an issue right now so this helps thanks for the reply😉👍
Old Jun 24, 2015 | 06:51 PM
J. Chris Davis's Avatar
Re: fuel tank size
Sorry to hijack this thread, but it is relevant to my issue. I changed the fuel pump before I had ever started the car and may have a bad gauge or I have the float in the tank flipped the wrong way. What can I do to test the gauge to make sure it is not that before I do all of the work in taking the tank back out to fix this. I have it full of gas right now and the gauge doesn't seem to move much from where it is at. Reads between quarter and half tank on the gauge. It will not read higher than that, but may read lower. I would have to run it out of gas to make sure on that.
Old Jun 25, 2015 | 02:07 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: fuel tank size
Very possible that the gauge is bad. It's common for the gauges to stop reading correctly.
Old Jun 25, 2015 | 03:44 PM
Re: fuel tank size
Is there any test I can do to determine it is the gauge and not the float or sending unit?
Old Jun 25, 2015 | 05:28 PM
scottmoyer's Avatar
Re: fuel tank size
I removed the gauge from the dash because mine was dancing all over the place and would show 1/4 when full. I plugged a meter into the jacks the gauge plugs into and went for a drive and monitored the voltage on the meter. Since the voltage wasn't dancing and remained fairly constant, I knew the gauge was bad.
Old Jun 25, 2015 | 08:11 PM
JT's Avatar
JT
Community Administrator
Re: fuel tank size
Since you indicate the gauge won't read higher than 1/2, an easy way to see if the gauge is capable of reading higher is to simply disconnect the fuel pump/sending unit connector under the car. You don't need to drop the fuel tank as there's a connector through the floor pan by the tank. Once you disconnect that, turn the key to On and see if the gauge reads full - as it should.
The gauge reads by measuring resistance through the fuel float. High resistance (or open) makes the gauge read high/full and low resistance makes the gauge read low/empty.
Old Jun 25, 2015 | 09:49 PM
Re: fuel tank size
Ok cool. Thanks for the information guys. I'm going out of town this weekend, but I have all of next week off and plan on working on the car. So I will be trying this stuff out to see what I find. Thanks again!
mustangman65_79
Apr 14, 2017 05:37 PM
toronto formula
Nov 10, 2015 06:17 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
AkDrifted
Aug 17, 2015 07:45 PM
knight72
Aug 10, 2015 09:32 PM
