Rear End
Old Dec 21, 2001 | 11:13 PM
Buck268's Avatar
Rear End
does anyone know specifics, or where to find them, on the rear end (gearing and such) of a 1991 Camaro RS?
Old Dec 22, 2001 | 12:43 AM
Drew's Avatar
unless the rear end has been changed the gearing will be 2.73 if its a V8 (l03) or 3.23 if its a V6 (LHO). The RPO codes will verify this, GU5 is 3.23's, can't remember the 2.73 code off hand. Otherwise there should be a stamped code in the front of the axle tube on the passengers side if you can read it... every manual I have says its there, but every car I've checked the diff is too rusted to tell... I should probably check out my convertibles diff one of these days, since its essentially the way it was off the showroom floor.
goodluck.
Old Dec 22, 2001 | 12:47 AM
Drew's Avatar
those numbers are asusming its an auto, if its a 5 spd, the V6 had 3.42 gears, and the V8 had 3.08's I believe...
BTW you can double check at https://www.thirdgen.org/newdesign/tech/techdb.shtml
Old Dec 23, 2001 | 12:18 AM
David M's Avatar
Car: '84 Z28
Engine: L69
Drew you are correct. L03/5spd's got the 3.08 gear and the L03/auto got the 2.73 gear.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
