Do I have an 89 1LE?
Old Mar 7, 2016 | 04:59 PM
Evanslooten's Avatar
Car: 1989 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.27 Posi
When I purchased my vehicle, it was said to be a 1LE IROC-Z. I didn't believe it, as the RPO sheet is gone and the vehicle has an assembled title. Well I took my vehicle down to 1MeanZ to give it a good appraisal, and decided it could actually be a 1LE.
I received paperwork from the previous owner documenting the previous VIN, which we were able to verify an exact match on a front bumper piece. The vehicle is hard top, has an aluminum drive shaft, hallow 32mm sway bar, large 2 piston front brakes with what seems to be an original one piece spindle, G92 rear end(?), and dual cat exhaust.
I have the original VIN available if it is any help!
Old Mar 7, 2016 | 06:24 PM
B4C5.7's Avatar
Car: 1989 IROC G92 LB9 MK6
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
Re: Do I have an 89 1LE?
1MEANZ is very knowledgeable and will be able to help you document the car. The last 8 of the VIN are stamped on the upper front rails under the fender to confirm origin of the unibody. What happened to the VIN?
Old Mar 7, 2016 | 06:25 PM
Car: 1989 IROC-Z
Engine: 5.7L TPI
The vehicle has an assembled VIN.
It has power accessories and AC which I've read are removed from the 1LE package, but it seems to have everything a 1LE would.
It was my hope someone might know some information that could confirm our suspicion based on the original VIN.
Old Mar 7, 2016 | 06:52 PM
JT's Avatar
JT
Community Administrator
Unless the vehicle is an exported vehicle, there is no public (free) resource to get that information from a VIN given it's a 1989. You would have to purchase a factory invoice from GM.
And given it's a nearly a 30 year old vehicle with an assembled VIN, it's certain parts were swapped.
Old Mar 7, 2016 | 07:19 PM
Car: 1989 IROC-Z
Engine: 5.7L TPI
I will look into it, thanks!
Old Mar 7, 2016 | 08:08 PM
BOTTLEDZ28's Avatar
Transmission: A4
Is there a 1LE RPO code on the white sticker in the hatch?
Old Mar 8, 2016 | 11:06 AM
mrestrictrplate's Avatar
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
Where is there a white sticker in the hatch located. Is it on all thirdgens? My car is home so I can't look. Is it a list of rpo's like under the arm rest?
Old Mar 8, 2016 | 12:35 PM
JT's Avatar
JT
The SPID sticker was moved from the center console to the locking cargo area in the hatch in 1991.
It's a really long shot to look in there for any ThirdGen that is 1990 and older because it's not supposed to be there.
Old Mar 8, 2016 | 02:19 PM
Car: 1989 IROC-Z
Engine: 5.7L TPI
The rpo sheet was in the center console, I can see fragments of it. It has just worn away beyond any legibility.
Old Mar 8, 2016 | 02:35 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Does Your Car Have A/C Or Fog Lamps.
Old Mar 8, 2016 | 03:43 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Hopefully, you can somehow document whether the car is an original 1LE or not. Anything can be added (my 85 is equipped with all the so-called 1LE stuff, for example) or removed for that matter.
JamesC
Old Mar 8, 2016 | 03:44 PM
87 player bird's Avatar
Car: 87 player's trans am a4u (pepsi car
Engine: 305 tpi
Transmission: 5 speed
Axle/Gears: 3:42
İf u were in canada any gm dealer could print out option codes from your vin. Being a us car not sure. Look up closest canadian dealer to you and call parts/service and ask if they can punch it into computer. İf it comes up, ask if 1le is in build. Good luck
Old Mar 8, 2016 | 05:37 PM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
This thread is funny!
Old Mar 9, 2016 | 08:47 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
If you want to know... go to http://www.gmmediaarchive.com/ and order yourself the dealer invoice... that would tell you... If it is a 1LE it will be worth the $50 investment.
Old Mar 9, 2016 | 02:45 PM
PurelyPMD's Avatar
Engine: LB9
If it's not a 1LE it will still be worth the investment.
Old Mar 9, 2016 | 02:53 PM
Car: 1989 IROC-Z
Engine: 5.7L TPI
Thanks okfoz, I have contacted them and am awaiting response. I'll let you know what I find out!
Old Mar 10, 2016 | 09:35 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Why is it funny? I'm usually the first guy to emasculate someone who thinks they have a rare or valuable thirdgen. I've spent more time under this car than over it, and if the brakes were swapped, it was done LONG ago, because the grunge on them is a dead ringer to the grunge on the rest of the car. The rotors are the proper 12" and the spindles are real deal 1LE spindles. No brackets, no tricks, not a swap with Ed Miller's kit etc.
I agree it's unlikely that it's a real 1LE, and this car has a questionable history. But it is a hard top, with an aluminum driveshaft, dual cats, 3.27 gear, and the big brakes. It also has leather seats and power windows and cruise control. The fog lights are some aftermarket stuff, I can't tell if it had any originally or not. The car DOES have AC, which looks to be original, which I know disqualifies 1LE as far as anyone here knows.
The car is either a real deal somehow, or it's been updated early in it's life with all the right factory parts by a very well informed thirdgen enthusiast.
Old Mar 11, 2016 | 07:11 AM
okfoz's Avatar
Personally I would love to see it be a 1LE, it would just blow the roof off of everything we think we know about them.
Old Mar 11, 2016 | 07:44 AM
BOTTLEDZ28's Avatar
Transmission: A4
A while back, someone ran a VIN for me and was able to get me every single RPO code for my Tahoe since the original glove box was swapped out at some point in the trucks past. Its a 1998 model year so Im not sure of there is a way to do the same with these cars. I guess it all comes down to how well someone or something (computer) kept records.
Old Mar 11, 2016 | 09:05 AM
okfoz's Avatar
There is, only if it was A) shipped originally to Canada, or B) if it is a 1990 - 1992. Nothing from the US for 1982-1989 for the F-car... Sucks really, it would have been nice to have access to that information
John
Old Mar 12, 2016 | 08:12 AM
PurelyPMD's Avatar
Engine: LB9
My apologies, it would be great if it was a 1LE and from what I understand a couple of them did get built in 1989 - there was one in the DC area about 10 years ago.
That being said, everybody wants to have a rare car and will sometimes build what they want when they can't find or afford what they want. This is why there are twice as many 1969 Z-28's or Judges as were ever produced and how correct 1LE parts can find their way onto cars they didn't belong on.
If this car turns out to be real, I'll be very happy to hear it!
Old Mar 12, 2016 | 07:58 PM
Time2Fly's Avatar
Car: 1991 Z28
Engine: 400 ci LS3
Transmission: Jerico DR4
Perspective guys, it's only a brake package…
Old Mar 12, 2016 | 08:16 PM
B4C5.7's Avatar
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
'It's only a brake package'...Please, it is a balanced performance package that included and deleted certain options. There are multiple threads that address the 'just a brake package' thought so won't do that here. Folks do some hating on the the 1LE's.
Old Mar 12, 2016 | 09:52 PM
85@IRocZ's Avatar
Car: Red 91 B4C, Burgundy 91 B4C,89 gta
Transmission: Auto, Manual
Axle/Gears: Posi
Right on B4C5.7!�� I won't bring up old treads but I've onwed heritage 1LE and now have a 92 1LE and I won't ask any question about them. But I hope it turns out to be a 1LE . I think it would be ��.
Old Mar 13, 2016 | 06:39 AM
PurelyPMD's Avatar
Engine: LB9
These discussions are good because they challenge the limits of what we think we know about these rare cars and what we actually do. JT has been helping me with some of the production numbers on the 1991 Formula 1LE cars and some interesting statistics have come out:
Of the 46 Formulas built - 9 came equipped with C60 Air Conditioning and 8 with T-tops (none shared both options). Where Chevrolet said no, Pontiac apparently said yes when it came to 1LE's in fact 6 of the 8 t-top models were built with the 1SC package!
Too bad Comp 9 doesn't include the data back to 1989 because that kind of information of the 26 TA's built that year would be great!
Pulling for you here on this rare car!
Old Mar 13, 2016 | 10:21 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
This article claims some 89 1LE cars had lightweight "mesh" wheels.
http://www.gm-efi.com/features/gm-efis-guide-to-the-3rd-gen-chevrolet-camaro/
Evan's car has GTA wheels.... I figured they were swapped on but?
Old Mar 14, 2016 | 07:14 AM
okfoz's Avatar
Funny thing is that the statement I found it on was for the 1988, which there was 4 1LE's made... in 1989 there was 111 made (IIRC)...
John
Old Mar 14, 2016 | 07:31 AM
PurelyPMD's Avatar
Engine: LB9
John
Camaro's John, those numbers are correct.
For TA's it was 3 in 1988 and 26 in 1989.
Old Mar 14, 2016 | 07:37 AM
B4C5.7's Avatar
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
The wheels have a date code, pull one off and let us know. This is interesting.
Old Mar 14, 2016 | 08:28 AM
okfoz's Avatar
Correct...
Also, I believe all of the 1LE Firebirds got the cross laced rims... The Camaro is kind of up in the air for 1988 & 1989... I have never seen one, but it might make sense since they were the lightweight wheels, which helps with performance, lowers unsprung weight, and overall weight. I know the GNX got the Black Cross laced wheels..
John
Old Mar 14, 2016 | 08:42 AM
PurelyPMD's Avatar
Engine: LB9
The two 1LE 88 IROC's I've seen pics of have the stock 16" IROC wheels John.
Old Mar 14, 2016 | 08:50 AM
okfoz's Avatar
That's what I have seen too... I do not believe the 1LE Camaros got the cross laced rims, it was based on that little website that has bad information. http://www.gm-efi.com/features/gm-ef...vrolet-camaro/
First there were NO L98 1986 Camaros... I found the reference to the 1LE and the cross laced wheels interesting, but it has no weight. THe article author is clearly not a tgo subscriber.
Old Mar 14, 2016 | 11:38 AM
PurelyPMD's Avatar
Engine: LB9
Not sure why but this whole time I've been reading this I've been under the assumption this was a Trans Am - I just went back and re-read the whole thing and saw it was an IROC.
Unfortunately there is no evidence A/C showed up in a 1LE Camaro and so far the only positive confirmation we have of it showing up in a bird is 9 1991 Formula 1LE's with the L98.
Old Mar 14, 2016 | 01:52 PM
Car: 1989 IROC-Z
Engine: 5.7L TPI
Where is the code located?
Old Mar 14, 2016 | 09:05 PM
B4C5.7's Avatar
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
On the back of the wheel, crosslace, in between the lug holes are recessed areas that have info like rear wheel, 16 inch, etc. in one of those recesses should be a round circle with the year on top and the month on the bottom. I have a March of 1990 built 1991 and the date code on one rear wheel is 12/89.
So there were nine L98/C60 1LE's built??? Did not know that.
Old Mar 15, 2016 | 12:04 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
So there is! Interesting...I didn't pay attention to that before. I only have one wheel off at the moment, but it says 8/87, and I think my build month was 9/87. Thanks for posting that.
Old Mar 15, 2016 | 05:41 AM
PurelyPMD's Avatar
Engine: LB9
JT & I were running different 1991 combinations through it over the weekend and that's what we found. Let the chase begin!
Old Mar 15, 2016 | 06:59 AM
B4C5.7's Avatar
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
Questions: We know this is reliable information, has anyone seen one? All '91 1LE Trans Ams are LB9 MK6 cars, was the L98 1LE a Formula only offering? Did any T/A or Formula include 1LE, CC1, and C60?
Really interesting thread.
Old Mar 15, 2016 | 07:01 AM
B4C5.7's Avatar
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
Old Mar 15, 2016 | 07:32 AM
PurelyPMD's Avatar
Engine: LB9
I'm going to start another thread on 1LE data rather than muddy this one up with information that doesn't belong, I just need to refine it a little better to see where we are and would like to pull up the 1990 data as well if I can.
To answer your question however, the L98 appears to only be in the Formulas in 1991 & 1992 and no CC1 & C60 do not seem to be combined in the data I've pulled.
Old Mar 15, 2016 | 07:47 AM
B4C5.7's Avatar
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
You are right, apologies for the off topic.
Old Mar 15, 2016 | 08:05 AM
  #42
okfoz's Avatar
Nope, No 1LE, CC1 & C60...
Plenty of 1LE + C60 (B4C Camaro perfect example, as well as several Formulas) and
plenty of 1LE + CC1 (No Camaros that I am aware of, but several Trans Ams and Formulas)
Old Mar 15, 2016 | 02:05 PM
  #43
Car: 1989 IROC-Z
Engine: 5.7L TPI
So I received the invoice copy from the GM Media Archive. Now I need your help to decipher it!
This excerpt is from camarowiki.com
Then in 1989, the option became more well-known as 111 were produced that year. The package was obtained by ordering the following:
Level 1 IROC-Z with 5.0 TPI engine (LB9) with 5 speed or 5.7 TPI engine (L98) with 4-speed automatic. These Camaro's had 145 mph speedometers and 5500 rpm redline tachs. Optional axle ratio (G92) (305/3.45, 350/3.27) and its required options G80 Limited-Slip rear axle
Package consisted of (G92 Was Ordered With A/C) [Street Vehicle]:
engine oil cooler 4-wheel disc brakes Performance exhaust system (N10) (dual catalytic converters) Tires P245/50 ZR16 Goodyear Gatorback
Note:
G92 ordered WITH A/C was classifieds as a Street vehicle.
G92 ordered WITHOUT A/C was classifieds as Race series.
1989
Chevrolet built 111 "1LE" 1989 Camaro's for the SCC A Showroom Stock racing series. But 1LE wasn't ordered like other RPOs. Ordering the RPO G80 Limited-slip rear axle & G92 performance axle with an IROC-Z Coupe triggered the 1LE RPO. Here's how it worked: When G92 was ordered, it forced several other options including engine oil cooler, 4-wheel disc brakes, dual converter exhaust and P245/50ZR16 tires. A 1989 Camaro with G92 had to have either the 350ci (RPO B2L) engine with 4-speed automatic transmission, or the 305ci (RPO LB9) with 5-speed manual. These Camaro's had 145 mph speedometers and 5500 rpm redline tachs. If RPO G92 was ordered with air condition ing, the cars were built as street vehicles. If air conditioning was not ordered, Chevrolet added 1LE equipment for the race series. This included aluminum drive shaft, big front brakes adapted from the Corvette, fuel tank baffles, specific front and rear shock absorbers, and different jounce bumpers. Also, fog lamps were deleted for weight savings and better air flow to the radiator.
On the invoice you'll see it has the 5.7L TPI, and also has the G92 and G80 codes. Additionally, AC and power accessories are added in 1SD not C60 & A codes.
So, is it a street 1LE, or a race series 1LE with delete items added in specially? Or not a 1LE at all?
File Type: pdf
Old Mar 15, 2016 | 02:17 PM
  #44
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
It appears it's not a 1LE, or there would be 1LE listed in the left margin with the other codes. Looks like the car has had lots of other mods along the way. Looks like the leather seats were swapped, as were the brakes, and the driveshaft.
The brakes were likely done a long time ago by someone with knowledge about these cars and who was willing to spend a LOT of money....
Old Mar 15, 2016 | 02:19 PM
  #45
Car: 1989 IROC-Z
Engine: 5.7L TPI
So even though the RPO wasn't an option it would still appear in the invoice?
Old Mar 15, 2016 | 02:24 PM
  #46
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Every 1LE I've seen says 1LE on the build sheet and the SPID. 1LE included stuff other than just the brakes.
Old Mar 15, 2016 | 02:25 PM
  #47
Car: 1989 IROC-Z
Engine: 5.7L TPI
This is an invoice though not a build sheet. They don't have build sheets available.
These are all present
I'm wondering since it wasn't something you could order, if it wouldn't show up on an invoice?
Old Mar 15, 2016 | 04:32 PM
  #48
okfoz's Avatar
I wanted it to be so, but it appears that it is not. The 1LE would have shown up, it was a pretty major option package.
It seems you have a super duper nice car, the 1LE brakes are a huge plus in my opinion, I am thinking of putting them on my 89 Convertible because they are much better than the stock brakes.
No worries, it is a cool car regardless...
John
Old Mar 15, 2016 | 05:50 PM
  #49
PurelyPMD's Avatar
Engine: LB9
Nice car, but not a factory 1LE.
mattbhm
Mar 29, 2016 06:18 PM
gcj280
Feb 23, 2016 09:58 AM
Chevy Iroc Z
Feb 15, 2016 10:23 PM
Matthew1821
Feb 12, 2016 06:08 AM
Chevy Iroc Z
Feb 10, 2016 04:53 PM
