Vin #
Old May 7, 2016 | 01:12 PM
Black_TA's Avatar
Car: 1983 Trans Am
Axle/Gears: Stock
Vin #
Can anyone help me, I spent some time on the phone this week with GM.
Trying to figure out why my Vin # does not come up anywhere in the
computer or anywhere online. Numbers do match under the windshield and front tag. I even found the build sheet 10 years ago. Maybe because pre computer
days. Here is a snapshot of my upper right hand corner of the build sheet.
Vin # 1G2AW87H5DN231826 matches under windshield and tag under hood.
What is the little 8 over the 1?
Thanks,
Al
1983 Trans Am
Old May 7, 2016 | 01:37 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: Vin #
I don't understand where you are trying to get your VIN to come up, or why you expect it should? The car is well over 30 years old. While I wouldn't call the 80's pre-computer days, if it were ever entered into a computer system, that system is probably long gone or archived and not likely to be connected to any internet server in use today. As for the numbers, look at the rest of the sheet. The little 8 is the cell number. Each cell has a number in the upper left corner. Just like when you do your taxes.
Old May 7, 2016 | 01:48 PM
Black_TA's Avatar
Car: 1983 Trans Am
Axle/Gears: Stock
Re: Vin #
When I registered the car I have the wrong vin #
on the title. Hard to see under the window covered with rust.
Old May 7, 2016 | 06:34 PM
JT's Avatar
JT
Community Administrator
Re: Vin #
Originally Posted by Black_TA
Trying to figure out why my Vin # does not come up anywhere in the computer or anywhere online.
Online where? Carfax shows 1G2AW87H5DN231826 is valid with 15 records. Autocheck shows 1G2AW87H5DN231826 is valid with 14 records.
There is no known online source that can provide you GM's records (such as RPO codes, etc.) because that information is not available online for pretty much anything older than 1990 - unless the vehicle is an export.
Old May 7, 2016 | 10:01 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Vin #
Thanks,
Al
1983 Trans Am
The "8" is just an identifier of the box on the build sheet form. Notice the box to the right of it is labeled "9". Kind of like your W2 you get from your employer.
Old Jul 25, 2016 | 10:45 PM
wildjeff's Avatar
Car: 1983 Trans Am
Engine: L69 5.0L HO
Transmission: Manual
Re: Vin #
The VIN is split between box 8 and 9. The 1G2AW87H5DN is the first part and box 9 (231826) has the last part. Together they make the VIN and should match what is on the car. In your case 1G2AW87H5DN231826 is the correct VIN based on the photo. The 127812 is a factory number of some sort.
EDIT -
NOTE: This is only true of Norwood cars, Van Nuys put the whole VIN in Box 9 and the VIN is also be in at the Bottom of the build sheet next to box 118.
Old Jul 29, 2016 | 09:44 AM
z28cop's Avatar
Car: 1985 IROC-Z
Engine: L69
Axle/Gears: 373 Limited Slip
Re: Vin #
The box numbers correspond to the parts we put on the car. Certain components required identifiers so we would not put wrong part on V8 car vs. V6 as an example. Our parts at our work stations had various part numbers for identifiers. We would loom at the Build Sheet and our specific box to see what part went on that particular car.
siuol
Apr 25, 2016 09:27 AM
MelodyS
Camaros Wanted
Apr 21, 2016 08:00 PM
68-87Chevy
Apr 9, 2016 06:29 PM
patracing
Apr 8, 2016 06:25 AM
firechickenmike
Interior Parts Wanted
Apr 7, 2016 07:52 PM
