Baffled Fuel Tank
Old Jul 9, 2016 | 01:44 PM
RonM's Avatar
Baffled Fuel Tank
Hi guys, I took the tank out of the '88 Trans-Am (TPI 305) today and found some interesting stuff. The tank has a metal baffle from one side to the other, the pass. side has a hole about 2'' in diameter the center is open to the bottom of the tank where there is some kind of a white plastic baffle and the driver's side of the tank has a wrap around type baffle and what looks like a tube coming from the filler neck exiting into the tank just to the side of the opening for the sending unit (I guess that's why I couldn't pour the fuel out of the filler neck). Also there is a PY sticker on the filler neck itself. It looks original with regards to undercoating. Is there a date code on these tanks like on the '68 Camaro? There just seems to be a lot going on in this tank compared to the wide open '68 Camaro tank. Thanks for any info., Ron.
Old Jul 9, 2016 | 02:03 PM
Drew's Avatar
Re: Baffled Fuel Tank
Sounds about normal. The code on the sticker should match the code on the build sheet if you have it. There's some debate about which cars got a baffled tank, but generally the later cars all have them, and all the "service" tanks were the baffled style - so if the tank was ever replaced, it'd be the late style baffled tank.
Old Jul 9, 2016 | 03:08 PM
RonM's Avatar
OK, being it's a baffled tank should I get the strainer for baffled tanks? The strainer on the pump now is the one for non-baffled tanks (I guess), meaning it only goes out in one direction from the pump instead of two. Thanks for any info., Ron.
Old Jul 10, 2016 | 11:32 AM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
The strainer should match the plastic baffle. My 1988 had a different plastic baffle compared to my 1989 1LE. So I can't say for certain if the wider strainer would fit properly.
Mark.
Old Jul 10, 2016 | 02:42 PM
RonM's Avatar
OK thanks, it has the standard strainer on it. I put about 70,000 miles on the car with it so I'll replace it with the standard one, which I already bought. Thanks for the info., Ron.
broke91firebird
Sep 2, 2019 10:02 AM
86ZRESTO
May 21, 2018 08:33 AM
soulreaper
Interior Parts Wanted
Mar 26, 2016 06:36 PM
thorpe991
Mar 18, 2016 10:21 AM
w41duvernay
Carburetors
Mar 15, 2016 03:54 AM
