Just bought 1992 B4C 1LE FBI
Old Jul 21, 2016 | 06:35 PM
rainmaker70's Avatar
Car: 83SC/84z28 autoform/2-84matrix3
Engine: LG4/L69/L69
Transmission: 5M/700r4
Axle/Gears: 3.73g80 j65 /3.73open
Just purchased 1992 green-gray rs I knew it was a b4c and 1le but didn't know it was an FBI car. It does have the GAM rpo guessing that means FBI? I would like to know more history on these cars supposedly only 16 or 17 ordered? If someone would like to run a compnine on it the vin is 1G1FP2385NL136710
Old Jul 21, 2016 | 06:42 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Just bought 1992 B4C 1LE FBI
Wow! Sounds like a great car. Have any photos?
Old Jul 21, 2016 | 08:33 PM
JT's Avatar
JT
Community Administrator
Compnine does not have history on a vehicle. Compnine only provides the RPO codes as well as some quantity figures.
The RPO codes for your VIN are as follows. Don't put too much into the definitions as they are generic for GM. I usually blank out the quantity figures because it leads to confusion and/or accuracy concerns. It's the RPO codes itself that are important.
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER)(USED WITH BERETTA GT PKG Z21) GA(UB3)
UM7 RADIO,AM/FM STEREO,ETR,INCLUDES CLOCK STEREO W/CLK(UM7)
UQ1 RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1)
U79 SPEAKER SYSTEM,4,DUAL FRONT COAX,DUAL EXTENDED RANGE PACKAGE SHELF 4 SPKR SYS(U79)
VAN PLANT CODE VAN NUYS, CA, CPC VAN NUYS,CA PLANT CODE(VAN)
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
Y86 CAMARO "RS" PACKAGE(MERCHANDISING OPTION) RS PKG(Y86)
1AA SALES INCENTIVE - RETAIL AMENITIES -- DELETE
1AZ ORDER MODIFICATION - ORDERS SOLD
1LE PERFORMANCE PACKAGE COMPONENTS PERF PKG(1LE)
1Q8 VEHICLE INSPECTION - GSA FORM 1398
1SA PACKAGE-OPTION 01 (1SA)
1SZ PACKAGE OPTION- (1SZ)
18Q MOLDING COLOR,DK GREEN GRAY METALLIC (18Q)
18U EXTERIOR COLOR,PRIMARY,DK GREEN GRAY METALLIC (18U)
19B TRIM COMBINATION,CLOTH,BLACK (19B)
19I INTERIOR TRIM COLOR (19I)
199 SEAT BELTS COLOR BLACK (19) (199)
6ZW SPRING COMPTR SELECT FRT LH SUSP(6ZW)
7ZW SPRING COMPTR SELECT FRT RH SUSP(7ZW)
8NL SPRING-COMPTR SELECT RR LH SUSP(8NL)
84P WHEEL COLOR,GUNMETAL GRAY (84P) 24,746
9NL SPRING-COMPTR SELECT RR RH SUSP(9NL)
AJ3 RESTRAINT SYSTEM,FRONT SEAT INFLATABLE DRIVER SI INFL RST SYS(AJ3)
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9)
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
A90 LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90)
B2L ENGINE PACKAGE-V8 5.7L, PFI ENG PKG(B2L)
B34 COVERING,FLOOR MATS,FRONT,CARPETED INSERT(COLOR COORDINATED) FRT CPT INS FLR MATS(B34)
B35 COVERING,FLOOR MATS,REAR,CARPETED INSERT(COLOR COORDINATED) RR CPT INS FLR MATS(B35)
B4C PACKAGE SPECIAL SERVICE POLICE PKG(B4C)
B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING(USED WITH TROFEO SPORT COUPE WL3) BODY SI MLDG(B84)
C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
D27 COVER,REAR COMPARTMENT STOWAGE LKG RR LOAD FLR(D27)
D35 MIRROR,O/S LH REM RH DIRECT CTL,PAINTED PAINTED O/S MIR(D35)
D42 COVER,REAR COMPARTMENT SECURITY(SHADE) R/CMPT SECURITY SHADE(D42)
D5X GEAR-SPEEDO DRIVEN (D5X)
D8I SENSOR-VEH SPD (10456089) (D8I)
D80 EXTENSION,REAR END PANEL(SPOILER) R/END PNL MOUNTED RR SPLR(D80)
EGW FLEET PROGRAM - DELAYED WARNING
E5Z ADAPTER - SPEEDO - DELETE
E9Z KEY - SPEEDO - DELETE
FE2 SUSPENSION SYSTEM,RIDE AND HANDLING(USED WITH TOURING YP5) RIDE & HANDLING SUSP(FE2)
GAM VEHICLE - GOVERNMENT (G.S.A. SALES)
GU5 AXLE,REAR,3.23 RATIO 3.23R(GU5)
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
IPB TRIM,INTERIOR DESIGN (IPB)
J65 BRAKE SYSTEM,POWER,FRONT AND REAR DISC 4-WHL DISC BRK(J65)
KC4 COOLING SYSTEM,ENGINE OIL ENG OIL CLG(KC4)
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
K68 GENERATOR,105 AMPERE 105 AMP(K68)
L98 ENGINE, 5.7L, (5.7-8) 350 CID, V8, TPI 5.7-8(L98)
MD8 TRANSMISSION,AUTOMATIC 4-SPEED(THM700R4/4L60) 4-SPD A/TRANS(MD8)
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX0)
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5)
NB8 EMISSION OVERRIDE CALIFORNIA SYSTEM EMIS SYS(NB8)
NK3 STEERING WHEEL,SPORT,SOFT RIM,SIMULATED LEATHER SIMULATED LEATHER STRG WHL(NK3)
N10 EXHAUST SYSTEM,DUAL(USED WITH TROFEO SPORT COUPE WL3) D/EXH(N10)
N64 WHEEL AND TIRE,SPACE SAVER SPARE(ALUMINUM) STOWAWAY SPARE(ALUM)(N64)
N96 WHEEL,16X8(CAST ALUMINUM) AL WHL(N96)
QLC TIRE,ALL P245/50ZR16/N BL R/PE ST TL HWY TIRE(QLC)
R6A CONTROL - SALES ITEM NO. 01
Old Jul 21, 2016 | 10:00 PM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
Very cool. Let's see some pictures.
Old Jul 21, 2016 | 10:57 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Congrat! Pics ASAP!
I've noticed that 1LE B4Cs don't have the JG1 Al DS.
Old Jul 27, 2016 | 12:58 AM
3rdgenparts's Avatar
On Probation
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
RPO GAM was for Federal Orders, I have seen it also on the 4th Gen Camaro and Firebirds !!
Not only did FBI have them but for some weird reason, Treasury department had F-bodys in their fleet.
Scratching my head on that one
Dave
Old Jul 27, 2016 | 01:42 PM
KMK454's Avatar
Car: 1991 Camaro B4C
Dave
Probably US Secret Service. They fell under the Department of Treasury until the establishment of DHS under President Bush.
Old Jul 28, 2016 | 09:31 PM
yaj15's Avatar
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
Is this the color of your car? That was a 1992 RS color only.
Attached Thumbnails Just bought 1992 B4C 1LE FBI-camaro1992darkgreengray.jpg
Old Jul 28, 2016 | 10:05 PM
Engine: LG4/L69/L69
Yes
Old Jul 28, 2016 | 10:16 PM
yaj15's Avatar
Car: 1988 IROC-Z
Post some pics we would love to see your car
92RS-HeritageEd
Mar 21, 2017 02:59 PM
LC2 TECH
Aug 18, 2016 11:37 PM
Black_TA
Jul 29, 2016 09:44 AM
Black_TA
May 7, 2016 06:25 PM
pmand
May 3, 2016 04:02 PM
