1514 MILE 4-SPEED 1982 Z28 PACE CAR
Transmission: 5-Speed Manual
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: 1514 MILE 4-SPEED 1982 Z28 PACE CAR
Nice!!! But shows some wear for such low miles. Also, who stole the leather shifter ****?
Car: 92 & 91 Z28 1LEs, 87 IROC-Z, 90 ZR1
Engine: L98, LT5
Transmission: 700R4, 6-speed
Axle/Gears: 3.45, 3.42, 3.73, 3.27
I have never understood the folks who go through the trouble of saving a car and then install generic tires and an econo power battery....
Engine: LS1, LB9, L03
They probably just bought it to flip it and are just trying to squeeze every penny out of it with no thought of adding value with correct parts. I could see the cheap battery, as you can't exactly really get a totally correct replacement battery. But those Nexen blackwalls look totally out of place.
Car: 1991 Camaro Z28
Engine: 305 cid
Transmission: 5 speed
Axle/Gears: Posi/3:42
I agree as well. It looks like the car was not stored properly. It's still a very nice example.
Axle/Gears: BW 3.45
Car: '87 IROC-Z
Engine: TPI 5.7
Axle/Gears: BW 3.45
Still has the gray valve stem caps:
The leather on the shift **** is known to "release" and separate from the ball. My father's did the same, so he injected some glue through the stitches, spun the cover around a few times and allowed the glue to dry. These people probably just removed the cover.
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
