My 1989, G92, 5 speed, N10, DX3, IROC-Z
#101
Received 1,160 Likes
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
Axle/Gears: 3.90 Currie 9 inch
Re: My 1989, G92, 5 speed, N10, DX3, IROC-Z
I wonder if you could make little "spikes" on the back sides of your floor mats with a hot glue gun?
I've been wishing I had factory carpeted mats in my car, but I know I'll never find them with a one year only interior color. I do have mint factory rubber floor mats....but it's just not the same. Although the pattern on my rubber mats matches the pattern on the door sill trim, so that's kinda different, I guess lol
#102
Someone needs to 3D print the GM logos for the purists.
I was worried about floor mats back when I put new carpet in my Formula. It was a bit nerve-racking driving the car since I was always worried about tracking dirt or water onto the new carpet. Eventually picked up a set of NOS floor mats, then realized that the floor mats were worth more than the ACC Carpet, and that they'd just get dirty too. Plus I didn't like the way they felt under my feet, or how they'd scrunch up under the pedals. Finally decided that it's a non-issue since the car never gets driven in weather, and that even if the carpet did get dingy it could be replaced against just as easily as the first time.
#104
Yeah, I wouldn't expect to see them as a licensed reproduction part, or from one of the typical vendors. I would think it'd be something that someone does for themselves, and potentially makes the files available to other like minded folks... But I suppose the legal aspect of it being a logo would prevent it from being done in any kind of mainstream, public, manner.
#105
Transmission: World Class T-5
Axle/Gears: BW 3.45
So, I'm going to bite the bullet and order some ACC mats for general use and save the factory mats if I ever show it.
But ACC has so many grays! Which one is the right one? I called ACC and asked for 3 of the gray color samples and they sent me this.
I've previously noticed that the driver's side mat and the passenger side mat were two slightly different shades. This makes it obvious. I think the second from the top seems like the closest. What do you guys think?
#112
I have gray ACC mats in my GTA in gray. The car is not nearby or I take some picts. The color was very close, I want to say the floor mats where a fuzz darker gray than the oem carpet. I also compared it to an area of the carpet that has never seen daylight & it was the same. So, not exact, but close enough where I didn't think they stood out.
I'll dig thought my files & see if I happened to take any pictures when I "installed" them
#113
Chaz, what color mats did you get, yours looked much better in your earlier pictures than the ones I bought.
I purchased Dove gray from ACC They are a bit too dark though. Fit nice though.
Unless the Birds have a lighter colored carpet, But I would think its the same gray as the camaros?
#114
Axle/Gears: BW 3.45
#116
#117
Axle/Gears: BW 3.45
See that oil stain on the floor? I've deduced that it is leaking from the AC compressor. The compressor has been spewing oil since day number one, but has gotten a bit more messy in the last couple of years or so.
It still holds a charge and blows cold, I've had to top it off twice in the past 10 or 15 years, though. I'd prefer to remove and reseal and keep the orignal, vs replacing it.
Thoughts and advice appreciated!
#118
Car: 87 Trans Am
Engine: 5.0
#120
Car: 87 Trans Am
Engine: 5.0
This is from the 1989 Firebird Service Manual - # 2 is the shaft seal - you can pick one up at your local Napa store
#122
Axle/Gears: BW 3.45
Is this it? They've got a bunch of them.
https://www.napaonline.com/en/p/TEM207256
[img]
https://media.napaonline.com/is/image/GenuinePartsCompany/NWMDC?$Product=GenuinePartsCompany/2112661
[img]
#123
Axle/Gears: BW 3.45
Another one...
https://www.autozone.com/cooling-hea...16276_127821_0
An AC Delco one, if that still means anything.
https://www.autozone.com/cooling-hea...17511_252237_0
#125
Car: 87 Trans Am
Engine: 5.0
Otherwise, you have a bunch of seals in this kit you wont need.
#126
Axle/Gears: BW 3.45
I guess I need to make sure it is in fact the shaft seal first. I believe it is because the compressor body is dry and the oil is on the clutch, front and wherever it spews. Space seems tight in front to get a puller on it though. I’d rather lose my R12 rather than risk damaging anything with a puller and close quarters while the compressor is on the car
#127
Car: 87 Trans Am
Engine: 5.0
Otherwise, there is a procedure in the factory manual for performing the shaft seal R&I with the compressor on the car -
you are a nervous nelly chaz.....
#128
Axle/Gears: BW 3.45
You can evacuate and re-claim your R-12 and then re-service the system with it if you have access to the proper equipment.
I don't have access to that equipment. I am indeed a nervous nelly! Do you have a copy of that procedure from the manual?
#131
Love the seal initiative to keep your original functioning pristine- did ya consider grabbing a backup?
Eg
https://www.kijiji.ca/v-engines-and-...ationFlag=true
but for serpentine
I was under the impression these units conk out eventually..
Eg
but for serpentine
#132
Axle/Gears: BW 3.45
I wouldn't be in this situation, had I simply ordered 1LE number 112 as I had intended.
#135
Oh yeah- I’d love the front brakes first and foremost.
This is interesting
http://sethirdgen.org/script/ac1.htm
This is interesting
#136
Axle/Gears: BW 3.45
This is interesting
This is interesting
Thanks! Hope BizJet hasn't forgotten about posting the service manual procedure.
#137
#139
Axle/Gears: BW 3.45
Thanks brother!
#142
Axle/Gears: BW 3.45
Sprucing up the black '89 for ThirdGen Expo.
#145
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
My guess saying “show glaze” is that it’s a very fine cut swirl remover finishing polish and you have to wax or seal after..
Always good to have good products for black paint!
#146
Axle/Gears: BW 3.45
My daily driver used to be black. It's just hard to just keep buffing a black daily over and over. Time consuming and also you will eventually run out of clear coat. So I applied Black Hole to it and wiped it off and ran out of time to wax over it. It actually last a few weeks.
#149
Axle/Gears: BW 3.45
Ready for ThirdGen Expo!!!!
