interior color rpo code?
Old Aug 22, 2017 | 05:58 PM
amlv20's Avatar
Car: 1986 iroc-z
Engine: 5.0 tpi
Axle/Gears: stock.
hey looking to get new interior for my 86 iroc from hawks.my iroc has a red interior but im not sure which one it is.any one have a list of interior rpo codes? thanks.
Old Aug 23, 2017 | 12:17 AM
Drew's Avatar
Re: interior color rpo code?
The White Book lists all the reds for 1986 as code 72? Where the ? determines which interior upholstery the car has.
72B : Red standard cloth
72C : Red custom cloth
72D : Red conteur custom cloth
72E : Red conteur standard cloth
72N : Red custom vinyl
72R : Red standard vinyl
Old Aug 23, 2017 | 12:11 PM
amlv20's Avatar
Car: 1986 iroc-z
Engine: 5.0 tpi
Axle/Gears: stock.
thanks,so was that carmine red or torch/flame red?
Old Aug 23, 2017 | 02:14 PM
j99birk's Avatar
Car: 1991 Camaro RS
Engine: LS1 swap in progress
Transmission: 4L60E swap in progress
carmine, the flame red RPO code starts with 73
reference:
http://www.rpocodes.com/GM-RPO-codes...5through9.html
Old Aug 23, 2017 | 11:10 PM
Drew's Avatar
It's best to avoid color names and stick to the codes. The thing is that in some cases the marketing teams at Chevy or Pontiac might refer to the same color with two different names. Aftermarket providers sometimes use a third name for the same color. The actual code should be specific. Probably not a bad idea to request a sample if you want to be sure.
Old Aug 26, 2017 | 03:37 PM
3rdgenparts's Avatar
On Probation
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
Get your interior from Rockauto.com, it ALL comes from the same company ACC or ACME, just no markup
Dave
