Do I have original factory engine?
Old Jun 25, 2018 | 12:14 AM
BamBam0515's Avatar
How can I tell or what can I look for to see if I have the original factory motor? I have a 1989 RS Camaro 2.8L
Old Jul 13, 2018 | 10:17 AM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Re: Do I have original factory engine?
Not the engine, but a partial VIN is stamped on the passenger's side of your transmission. It is unlikely that if a previous owner removed the original engine they would have replaced it with another 2.8L power plant. Most swaps would have upped the vehicle power and gone to something bigger. If the trans has a different number than is on your windshield label, its a good bet that both the engine and trans were swapped out from the originals.
Old Jul 13, 2018 | 10:47 AM
JT's Avatar
JT
Community Administrator
Partial VINs (last digits) of the car are stamped on the engine. Atleast on the V8s. Would think the V6 is no different. Look around the front near the water pump for it to be stamped on the pad. Most likely it will be covered with dirt, grease, etc.
scottmoyer
Jul 21, 2013 05:06 PM
yayoWHITESACK
Jan 9, 2013 10:02 AM
Foggie Doggie
Northern California
Oct 1, 2012 01:29 PM
j88l98irocz
Apr 6, 2012 07:23 AM
