Compnine subscribers
Car: 1992 Z28 1LE
Axle/Gears: SLP dana 44 3.92
Can somebody run and post the RPO's for this one?
1G2FS2381ML207684
its a black 91 formula 350 hardtop. The car has rough paint, and missing the wing, it's a "non runner" back-lot special at a cheese ball used car lot. Just wondering if it's working snagging and saving. It's not rusty at all, and when I asked how much they wanted for it they owner of the lot said $1000 it's yours so I'm going to assume even cheaper if I show up with cash. The last thing I need is another project, but I always liked the 91-92 formula just like everybody else haha
1G2FS2381ML207684
Car: 1992 Z28 1LE
Re: Compnine subscribers
lol I didn't even call the guy back today as I was super busy and he called and left s voicemail and said $600 buys it. I bet $400 tomorrow cash will take it 😂😂
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
Report for..1G2FS2381ML207684
Vehicle:
FIREBIRD 2 DR
Year:
1991
Build Date:
1990-04-10
It's a black 1991 Formula 350 with N10 and 3:23 and G80 POSI
Found 47,612 vehicles matching that year and model in our database.RPODescriptionMatchesUB3CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER)(USED WITH DELUXE SPORT PKG W32) GA(UB3)47,612UQ1RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1)47,612UX1RADIO,AM/FM STEREO,WEATHER,CASSETTE,EQUALIZER,ETR,INCLUDES CLOCK STEREO AM/FM W/CASS & EQLZR(UX1)28,268U62SPEAKER SYSTEM,4,DUAL COAX FRONT,DUAL COAX PACKAGE SHELF 4 SPKR SYS(U62)47,612U75ANTENNA,POWER(CHROME) PWR ANT(EXPORT)(U75)18,779VANPLANT CODE VAN NUYS, CA, CPC VAN NUYS,CA PLANT CODE(VAN)47,612V73VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)44,388WS6PERFORMANCE PACKAGE,SPECIAL(MERCHANDISING OPTION) SPECIAL PERFORMANCE PKG(WS6)10,360W66FORMULA OPTION(MERCHANDISING OPTION) FORMULA(W66)5,4641SCPACKAGE-OPTION 03 (1SC)24,56915PWHEEL COLOR,MEDIUM SLATE GRAY (15P)5,38219QMOLDING COLOR,BLACK (19Q)7,83141UEXTERIOR COLOR,PRIMARY,BLACK (41U)7,9656ZWSPRING COMPTR SELECT FRT LH SUSP(6ZW)7,58766CTRIM COMBINATION,CLOTH,BEECHWOOD (66C)6,34566IINTERIOR TRIM,MEDIUM BEECHWOOD (66I)7,252669SEAT BELT COLOR,MEDIUM BEECHWOOD (669)7,2527ZWSPRING COMPTR SELECT FRT RH SUSP(7ZW)7,5878NLSPRING-COMPTR SELECT RR LH SUSP(8NL)11,1029NLSPRING-COMPTR SELECT RR RH SUSP(9NL)11,102AAAUnknown46,052AH3ADJUSTER,SEAT,4-WAY MANUAL,DRIVER 4-WAY MAN D/SEAT ADJR(AH3)13,751AJ3RESTRAINT SYSTEM,FRONT SEAT INFLATABLE DRIVER SI INFL RST SYS(AJ3)47,612AR9SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9)44,743AU3LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)41,671A31WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)41,671A90LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90)28,389BC8ORNAMENTATION,INTERIOR,FRONT DOOR MAP POCKET RH AND LH DR MAP PKT(BC8)41,671B2LENGINE PACKAGE-V8 5.7L, PFI ENG PKG(B2L)3,489B84ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING(USED WITH APPEARANCE PACKAGE Z12) BODY SI MLDG(B84)46,790C49DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)33,076C60AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)46,946DC4MIRROR,INSIDE,REARVIEW TILT,DUAL READING LAMP I/S DUAL READING LP RR VIEW MIR(DC4)46,761DG7MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL,ELECTRIC(PAINTED)(USED WITH SE Z7M,STE Z7N,LE Z7K) O/S ELEC R/CON PAINTED MIR(DG7)27,108D5XGEAR-SPEEDO DRIVEN (D5X)3,489D8FSENSOR (D8F)1,221D81SPOILER,REAR,AERO WING RR AERO WING SPLR(D81)13,733E5ZADAPTER - SPEEDO - DELETE47,612E9ZKEY - SPEEDO - DELETE47,612FE2SUSPENSION SYSTEM,RIDE AND HANDLING(USED WITH PERFORMANCE PACKAGE WS6) RIDE & HANDLING SUSP(FE2)10,360GU5AXLE,REAR,3.23 RATIO 3.23R(GU5)26,461G80AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)9,171IPCTRIM,INTERIOR DESIGN (IPC)44,743J65BRAKE SYSTEM,POWER,FRONT AND REAR DISC 4-WHL DISC BRK(J65)3,474KC4COOLING SYSTEM,ENGINE OIL(EXPORT-IRAQ) KC4(EXPORT IRAQ)4,569K34CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)30,237K68GENERATOR,105 AMPERE 105 AMP(K68)8,835L98ENGINE, 5.7L, (5.7-8) 350 CID, V8, TPI 5.7-8(L98)3,489MD8TRANSMISSION,AUTOMATIC 4-SPEED(THM700R4/4L60) 4-SPD A/TRANS(MD8)43,399MX0TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION)(MD8) A/TRANS PROVISIONS(MX0)43,399NA5EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5)43,196N10EXHAUST SYSTEM,DUAL(USED WITH TOURING YP6) D/EXH(N10)4,569N36STEERING WHEEL,SPORT-4 SPOKES SPORT STRG WHL(N36)41,430N64WHEEL AND TIRE,SPACE SAVER SPARE(ALUMINUM) STOWAWAY SPARE(ALUM)(N64)7,327PE0WHEEL,16X8,ALUMINUM,LIGHT WEIGHT STYLED LGT WT AL WHL(PE0)5,382QLCTIRE,ALL P245/50ZR16/N BL R/PE ST TL HWY TIRE(QLC)10,360R6PCONTROL - SALES ITEM NO. 153,005
Vehicle:
FIREBIRD 2 DR
Year:
1991
Build Date:
1990-04-10
