RPO codes help
Old Apr 18, 2020 | 05:04 PM
Moonlightlady79's Avatar
RPO codes help
Not sure if this is the right forum to post in, but I need help finding the last few RPO codes for my 1986 Transam.
The codes I need are as follows:
D3W
D42
BX5
N24
UM6
U66
WW4
7XY
Thanks for your help.
Old Apr 18, 2020 | 05:10 PM
Drew's Avatar
Re: RPO codes help
Use Google. Type the code you want to find, and then site:thirdgen.org and it'll usually find what you're after.
D42 is the locking cover in the trunk well. N24 is probably the wheels. UM6 is the radio. 7XY is going to be a spring code.
Old Apr 19, 2020 | 02:39 PM
Re: RPO codes help
Thanks. Most of the codes I ended up finding. However the code for D42 looks like a rear cargo screen.
Old Apr 19, 2020 | 03:19 PM
Drew's Avatar
Re: RPO codes help
Could be, it's one or the other, I don't remember which.
Old Dec 18, 2020 | 09:31 AM
83tranzam's Avatar
Car: 1985 Trans Am
Engine: LB9 5.0 TPI
Re: RPO codes help
N24 is the 15" aluminum wheel package used on Trans Am's and Firebirds from 1985-1992. I was curious about that WW4 code too since mine has it....I know it's "AERO PKG #4 BLACK" but not sure what exactly this means.
86LB9
Oct 9, 2002 05:00 PM
iroc_cragg
Mar 3, 2002 11:11 PM
