Norwood build sheet location
Old May 31, 2020 | 11:28 AM
Iroc588's Avatar
Car: 1986 Yellow Iroc /1987 Blue Iroc
Engine: All 5.0 LB9 TPI
I’m trying to find my build sheet if my car has one I have looked under the carpets in the back all the way up and no dice. My car was built in April/March of 86 and was built In Norwood Ohio any help will be greatly appreciated
Old Jun 1, 2020 | 09:51 AM
LeonardS's Avatar
Re: Norwood build sheet location
I found one that was stuck in the springs of the back seat, bottom cushion.
Old Jun 1, 2020 | 01:07 PM
kentuckyKITT's Avatar
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
Good luck to you! I've completely dismantled two cars and never found them. I did find a pair of gray gloves under the rear carpet in my 82 though back in 2007 with the GM logo on them. Still have those in a bag somewhere!
Old Jun 6, 2020 | 01:21 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
I've found some on the floor in rear seat well under the carpet. I've seen people say they are under the seats, but not personally seen them.
Old Jun 6, 2020 | 03:51 PM
JT's Avatar
JT
Community Administrator
There was no specific location for the buildsheet and it wasn't necessarily included in the car. It was considered "trash" but some made it into the vehicle and some did not.
Different spots have been reported by those who've found one. Also, there was different buildsheets such as trim sheets, etc., and it's only the master buildsheet that will contain all RPO codes as well as the dealership who ordered the vehicle.
Old Oct 2, 2020 | 11:43 AM
randyhummel's Avatar
Car: 1986 Iroc-z, 1968 Camaro RS-ss
Engine: 305, 396
Transmission: auto
I found my trim sheet under the rear trunk carpet tapped in the well on the passenger side. I plan on making a copy an putting the copy back were i found it.
Old Oct 2, 2020 | 10:34 PM
Jenkins's Avatar
Car: 1984 Trans Am
Engine: Lg4
Axle/Gears: 3:23
That’s where I found mine. In the springs under front seat. Wasn’t looking for it, I dropped something and felt some paper. Pulled it out, there is was.
Old Oct 2, 2020 | 10:39 PM
Jenkins's Avatar
Car: 1984 Trans Am
Engine: Lg4
Axle/Gears: 3:23
Sorry. Forgot mine is a Van Nuys car.
mauljeremy
Jul 25, 2018 08:06 PM
jrz28
Jul 15, 2011 09:39 PM
1bad86
Jul 2, 2006 02:59 AM
stuart69427
Mid-Atlantic Region
Oct 27, 2003 12:33 PM
