Can anyone get RPO codes off a VIN?
Old May 11, 2021 | 10:05 PM
9sinthe86TA's Avatar
Car: 1986 Pontiac Trans Am WS6
Engine: 383 Stroker
Transmission: TCI 725hp built 700R4
Axle/Gears: 94 Camaro 10 bolt. Posi 3.23
Hello, my cars RPO codes have fallen off back when Jimmy Hoffa was around.
The vin is 1G2FW87F3GL220998
Its a 1986 Trans Am
And yes I've tried https://www.compnine.com/vid.php and it will not work for some reason
Old May 11, 2021 | 10:28 PM
JT's Avatar
JT
Community Administrator
Re: Can anyone get RPO codes off a VIN?
Its a 1986 Trans Am
Compnine only has 1990 and newer ThirdGens as well as exported ones. That they don't have your 1986 is normal. There is no public way of getting all RPOs from a VIN that isn't in Compnine's database. You can order a copy of the invoice, however, it won't contain all RPO codes but only some of the major ones.
http://www.phs-online.com/index.html
Old May 11, 2021 | 10:31 PM
Engine: 383 Stroker
Ah ok. I can basically make a new RPO code paper, just by seeing what options were available and what's on my car. Im pretty sure my car was fully loaded from the factory
redcamaro83
Sep 18, 2006 11:31 PM
vejatabul
May 25, 2005 12:21 AM
SC82TA
May 13, 2003 10:40 PM
CaysE
Oct 8, 2002 09:25 PM
91-Z-Speed
Aug 13, 2002 03:16 PM
