Carpet& console color
Old May 19, 2021 | 02:08 PM
mrestrictrplate's Avatar
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
Hello. When these cars were new on gray interior cars, were the floor carpets the exact same color as the console carpets on say an 87 cars? Were the console carpets a little darker? I'm sure guys with the low mileage cars can answer if their cars were garage kept. Thanks Chris.
Old May 19, 2021 | 04:04 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: Carpet& console color
It was the same color carpet used for both, so the color should be the same. What you might see is discoloration due to the floor position and the the UV damage. Why does it impact the floor more than the side? I don't know, but it's not only grey cars. I have an '82 with blue carpet and the console is now a different shade than the console.
Old May 19, 2021 | 07:12 PM
IROCIN's Avatar
Car: Irocs 87 Conv 5 spd & 87 T-Top auto
Engine: LB9/L98
Transmission: MM5/Auto
My tan interior is a little off from the old console carpet as well.
Old May 19, 2021 | 08:23 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
My red is slightly off also.
Old May 20, 2021 | 03:55 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Comparing a new piece of carpet to an old piece of carpet of the same color, the colors will always be "off." Comparing a new piece of carpet to another new piece of the same color, even from the same dye lot, the colors can look "off."
Viewing angles make a difference. For example, looking up the carpet(rear to front), where it's grain is partially laying down, so you're looking mostly at the sides of the carpet fibers, the color will have a lighter appearance. Looking down the same piece of carpet(front to rear), where its grain is partially standing up, so you're kind of looking into the tops and down into the depths of the carpet fibers, the color will have a darker appearance. Even looking across the grain of the same piece of carpet(side to side), it will have a slightly different color, yet.
So for this topic, where some carpet is laid vertically(on the sides of the console), and some carpet is laid horizontally(on the floor), the colors will always look "off," regardless that each piece is the exact same color, even if each piece is cut from the same larger piece, whether each piece is new, each piece is old, or one piece is new and the other old.
No matter what color someone chooses, it's going to have a slightly different appearance after its installed, due to the various angles at which its laid, and from which it will be viewed. And since ACC's colors aren't good matches anyway, then request several different samples that appear to be similar in color and trust your own judgement to select the one that best suites your interior. Because with the variety of different shades of the same color in the interior, seat color, door panel color, carpet color, floor mats, all of which are similar, but none of which are the same, better to try to coordinate and be happy, rather than try to "match" and be disappointed.
Old May 20, 2021 | 06:57 PM
scottmoyer's Avatar
I'm assuming that the carpet used on the console is of a different make up than that on the floor, so it fades differently also. If it was all new, as discussed, the angle will give it the appearance of different shades, but as these cars have aged, it's clear that the carpet and console carpets have faded differently.
Old May 20, 2021 | 07:29 PM
I'm trying to remember if the console and floor carpets were the exact color when these cars were new. I wonder if they were a tiny shade different.
82tarecaro
Sep 19, 2010 09:24 PM
sweetpea12
Jul 3, 2008 08:24 PM
ranone21
Interior Parts Wanted
Aug 12, 2007 11:51 PM
Kandied91z
May 11, 2007 12:53 PM
Gallstaff
May 14, 2004 07:13 PM
