Look what followed me home. ‘87 Formula
Old Jun 5, 2023 | 07:57 PM
  #101
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: Look what followed me home. ‘87 Formula
I was surprised when I saw the 3.23 gear on the SPID. I was expecting a 3.08.
Old Jun 5, 2023 | 09:27 PM
  #102
JT's Avatar
JT
Community Administrator
Me too but I was also wondering if the drums were originally aluminum, which it appears not. My 1988 T/A is fairly loaded (T-Top, LB9, digital cluster and deluxe interior) but has the 2.73 gears with aluminum drive shaft and aluminum rear drums.
Old Jun 6, 2023 | 04:07 PM
  #103
chazman's Avatar
Axle/Gears: BW 3.45
I really like the '87 LG4s. They are sooo much better than the early ones. They almost should have renamed it LG5 or something, that's how different they are. The one in my '87 IROC, was smooth and torquey. It was only let down by it's 700R4 tuned to hit top gear ASAP and it's 2.73 gears. This one with a 5 speed and 3.23 gear is a whole different animal. I have a few bugs to work out though.
Old Jun 7, 2023 | 07:32 PM
  #104
chazman's Avatar
Axle/Gears: BW 3.45
First piece is here.
Old Jun 8, 2023 | 03:11 PM
  #105
chazman's Avatar
Axle/Gears: BW 3.45
I’ve never seen this before. Split from front to back.
Old Jun 8, 2023 | 07:22 PM
  #106
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
What's the other side of that lid and air cleaner base look like, where the duct is? It looks like there's a wide-open hole through the side of the air cleaner base, in the view you've posted. How about a view of the side that I'm asking about? I'm wondering if that lid could be used on a different base.
Because if the base units are all the same size, and that lid can be used on a different base, then something else that might help you unlock even MORE POWER (great clickbait caption on that video, and a sense of humor lol) with your functional cowl induction unit and lid, is an L69 dual snorkel base under that lid. The L69 base has a 15" diameter where the lid sits on it.
I know you're a very "factory-stock" guy, so I don't know if something like that would be too radical of a change for you or not, but I think it would be an interesting combination.
Is that other picture of an exhaust pipe? Was that on the car?
Old Jun 8, 2023 | 07:31 PM
  #107
chazman's Avatar
Axle/Gears: BW 3.45
I'll post a pic later.
There is an inner lid which seals with air cleaner element. And yes, I could put that lid on my L69 dual snorkel system.
Yes, that is the factory pipe. All pre-bent systems for our cars are sold out or back ordered, so I had one fabricated.
Old Jun 8, 2023 | 08:11 PM
  #108
chazman's Avatar
Axle/Gears: BW 3.45
Old Jun 9, 2023 | 06:06 AM
  #109
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
That's a new one on me too.
Old Jun 10, 2023 | 03:15 PM
  #110
chazman's Avatar
Axle/Gears: BW 3.45
Here we are. With screen and driprail
Old Jun 10, 2023 | 03:41 PM
  #111
chazman's Avatar
Axle/Gears: BW 3.45
Anyone have any pics of an '82-'84 T/A with this system when new-ish? Hood insulator set up, etc.
Old Jun 10, 2023 | 05:02 PM
  #112
chazman's Avatar
Axle/Gears: BW 3.45
Everything is nicer cleaned a painted.
Old Jun 10, 2023 | 09:30 PM
  #113
chazman's Avatar
Axle/Gears: BW 3.45
I'm not hooking up the solenoid for now. I just want to jam the flap open.Any ideas on how best to do that?
Old Jun 10, 2023 | 10:04 PM
  #114
tajoe's Avatar
Car: 84 Trans Am
Engine: Turbo 301
Mines an 84, and not sure if your linkage is different. But I would remove the screw securing the solenoid lever to the flapper shaft, remove the entire solenoid, and linkage and save. Reinstall the screw with some wire under it, and anchor the wire "somewhere", to hold the valve open. Should be simple enough.
Old Jun 11, 2023 | 12:20 PM
  #115
chazman's Avatar
Axle/Gears: BW 3.45
Once the scoop becomes functional what about the hood insulation??? Does it stay or go or get trimmed. I've been searching and haven't come across any pic of the insulator on an original factory car.
I'll have a few days to think about it, since it's going to the body shop tomorrow morning to have rusted battery tray cut out and new replacement welded in.
Old Jun 11, 2023 | 12:32 PM
  #116
chazman's Avatar
Axle/Gears: BW 3.45
Thanks!
Old Jun 11, 2023 | 02:29 PM
  #117
tajoe's Avatar
Car: 84 Trans Am
Engine: Turbo 301
Not a fan of hood insulation on a performance car. It can get pretty messy. but if already in place, and is serviceable, i would leave it...for now.
Old Jun 11, 2023 | 04:26 PM
  #118
chazman's Avatar
Axle/Gears: BW 3.45
Finally! I found a pic of a stock setup with it's hood insulator.
Old Jun 11, 2023 | 04:39 PM
  #119
tajoe's Avatar
Car: 84 Trans Am
Engine: Turbo 301
Wow. Nice shot. Is it yours, or generic? Looks brandy new, or lots of clear coat.
Old Jun 11, 2023 | 04:49 PM
  #120
chazman's Avatar
Axle/Gears: BW 3.45
No, just found it online. Hard to find a pic of the set up WITH the hood insulator.
Old Jun 12, 2023 | 01:02 PM
  #121
chazman's Avatar
Axle/Gears: BW 3.45
Rusted battery tray is probably being cut out as we speak.........I bought a new one which will be welded in.
Old Jun 12, 2023 | 06:52 PM
  #122
chazman's Avatar
Axle/Gears: BW 3.45
New battery tray in.
Old Jun 12, 2023 | 07:04 PM
  #123
JT's Avatar
JT
I don't see a battery tray, but I do see it must have the add-on carb blower kit to help with fuel boiling?
Old Jun 12, 2023 | 07:07 PM
  #124
chazman's Avatar
Axle/Gears: BW 3.45
Yes, it has one of those.
There was nothing there where the hold down is. That was rust and air 12 hours ago.
Old Jun 13, 2023 | 01:57 AM
  #125
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Thought there was a picture of the stuff installed on that thread i posted on fb from here.
If you hold the air induction parts up in place under the hood you'll see exactly how to hook it all up. There's a little hole in the blanket for the front leg to poke through and sit on the top side of the hood brace. Then its just the 7mm screw holding that in.
Old Jun 13, 2023 | 09:16 AM
  #126
chazman's Avatar
Axle/Gears: BW 3.45
Thanks Tony for the links to those excellent threads. None of them had pics of the airbox installed with the hood insulator though.
Old Jun 13, 2023 | 05:04 PM
  #127
chazman's Avatar
Axle/Gears: BW 3.45
This beater has Ram Air!!!
https://www.youtube.com/shorts/FGdVbOySKno
Old Jun 13, 2023 | 05:14 PM
  #128
tajoe's Avatar
Car: 84 Trans Am
Engine: Turbo 301
Sweet. Now let's have a "performance" comparison. Drag times with it open, and closed.
Old Jun 14, 2023 | 07:41 AM
  #129
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Charlie, does your car have the Subwoofer option?
Old Jun 14, 2023 | 09:07 AM
  #130
chazman's Avatar
Axle/Gears: BW 3.45
I don't know John, what's the code?
Old Jun 14, 2023 | 02:55 PM
  #131
okfoz's Avatar
If you have a button on the dash with a slider, you would have the subwoofer. The reason I ask is you have the fancy speaker grilles. I am not sure if it was part of the subwoofer package or if it is part of the Custom interior.
Old Jun 14, 2023 | 03:09 PM
  #132
JT's Avatar
JT
Subwoofer option code is UQ7. It is not listed on this vehicle.
That's interesting about the speaker covers, John. My 1988 T/A has the deluxe interior but does not have the speaker covers. It also doesn't have the UQ7. I suppose someone could have changed Charlie's or changed mine.
Just checked my GTA, which of course has the deluxe interior but no UQ7, and it does have the fancy speaker covers.
Old Jun 14, 2023 | 03:32 PM
  #133
chazman's Avatar
Axle/Gears: BW 3.45
The faded ones on my dash pad?
  #134
JT's Avatar
JT
Yes, your purple covers.
Old Jun 14, 2023 | 03:36 PM
  #135
okfoz's Avatar
Here is what I found:
Standard Grille
83 (2nd Des) - 92
10077214 (LH) & 10077215 (RH)
Cloth Grille
85-86 U52 (Digital Dash)
87-88 B20 (Luxury Trim Group)
10077211 (LH) & 10077212 (RH)
Chaz has the B20
I thought it was part of the subwoofer option, but apparently not. I ended up removing my purple covers and painting the mesh black, it looks better than the pealing cover. However you could get some new speaker material and cut them out and glue it on. I have considered doing that.
Old Jun 14, 2023 | 04:36 PM
  #136
chazman's Avatar
Axle/Gears: BW 3.45
I'm learning a lot about Firebirds.
Old Jun 14, 2023 | 04:46 PM
  #137
JT's Avatar
JT
Standard Grille
83 (2nd Des) - 92
Cloth Grille
Chaz has the B20
I think you're right that it's part of the B20, even though B20 is defined in the 1987 product manual and speaker covers are not mentioned. That is not conclusive, though.
I'm starting to think that I did remove the covers on my '88 T/A (B20) because of the same reason as you where the cloth was peeling. In fact I just looked at my past pictures over 20 years ago and confirmed it did have them. So B20 does appear to be the factor.
Old Jun 14, 2023 | 08:50 PM
  #138
chazman's Avatar
Axle/Gears: BW 3.45
Strange that my car has the luxury trim group, yet has manual windows and locks.
Old Jun 14, 2023 | 08:53 PM
  #139
chazman's Avatar
Axle/Gears: BW 3.45
Originally Posted by Agent13
Welcome to the dark side.
Looking forward to seeing your progress with it. Definitely source a fiberglass replacement for that spoiler.
Any other choices besides Hawks?
Old Jun 14, 2023 | 08:58 PM
  #140
chazman's Avatar
Axle/Gears: BW 3.45
Also, I don't see 1AZ vs 1AY codes on the SPID regarding if it was a customer order vs dealer order.
Old Jun 14, 2023 | 09:02 PM
  #141
JT's Avatar
JT
They ordered the W63 package:
C60 = A/C
N33 = Tilt Steering wheel
AK1 = Colored Keyed Custom Belts
UM7 = ETR AM/FM Radio
B84 = Color Coordinated Custom Body Side Moldings
CD4 = Controlled Cycle Wipers
TR9 = Lamp Group
K34 = Cruise Control
A31 = Power Windows
AU3 = Power Door Locks
A90 = Remote Deck Lid Release
But notice, instead of A31 and AU3, you got B6W and B6V. W63 allowed the deletion of power windows (B6W) and deletion of power locks (B6V) from the above list for a discount.
So, yeah, they definitely did not want power windows and locks because they specifically deleted it from the W63 package.
Old Jun 14, 2023 | 09:04 PM
  #142
chazman's Avatar
Axle/Gears: BW 3.45
C60 = A/C
TR9 = Lamp Group
A31 = Power Windows
So, yeah, they definitely did not want power windows and locks because they specifically deleted it.
Interesting.
Old Jun 16, 2023 | 08:04 AM
  #143
okfoz's Avatar
Classic Industries also sells an "OER" aero Spoiler, but it looks awful, I would never use one of theirs because the spears are way way too thick. Hawks spears are also a little thicker than stock, but it just has the better appearance for aftermarket. Hawks is worth the wait IMHO.
Old Jun 16, 2023 | 08:05 AM
  #144
okfoz's Avatar
I got the information from the Parts & Illustration Catalogs.
Old Jun 16, 2023 | 08:37 AM
  #145
okfoz's Avatar
Here you go.
AAA - Standard Equipment
AK1 - Seat Belts Color Keyed
AM9 - Split rear folding seats
AR9 - Front Bucket Seats - Deluxe
A01 - Glass - Soft Ray ( Green )
A90 - Rear locking Compartment
BY4 - Interior Ornamentation ( Performance suspension Emblem? maybe)
B20 - Luxur Trim Group
B34 - Front Floor Mats
B35 - Rear Floor Mats
B6V - Power Door Lock Delete
B6W - Power Window Delete
B67 - Cassette Tape Storage Container
B84 - Ornamentation, Exterior Body Side molding
B87 - Emblem Exterior Fender (Which interestingly they stopped putting on Formulas early 1987, but they still got the RPO)
CD4 - Windshield washer, control Cycle
C49 - Rear Defog
C60 - Air Conditioning
D35 - LH Remote Cable Mirror Painted
D42 - Rear Cover Security Shade
D5R - Speedo Driven Gear (3.23)
D81 - Aero Spoiler
D86 - 2 Tone Paint
D9E - Vehicle Speed Sensor
D98 - Stripe Body Accent
E5Z - Adapter Speedo - Delete
E9Z - Speedo Gear Delet
FE2 - Performance Suspension Part of WS6
GU5 - 3.23 axle
J50 - Rear Drum Brakes
K34 - Cruise Control
K60 - 100 Amp Generator
LG4 - 5.0L 4BBL
MM5 - Manual trans provisions
M39 - Manual Trans
NA5 - Fed Emissions
NK3 - 3 Spoke Sport Steering Wheel
N33 - Tilt Steering Wheel
N65 - Spare Tire - Steel Space Saver
N96 - 16x8 Aluminum Formula Wheels
PB4 - Aluminum Wheel Locks
QDZ - Tires - P245-50R16
TR9 - Lamp Group
UF6 - Lamp, interior console and courtesy
UM6 - Radio AM/FM Stereo & Cassete, ETR
UQ1 - Radio Provisions
UT1 - Warning Tone Generator
U21 - Gage Package
U25 - Rear Compartment Lamp
U29 - Lamp, interior instrument Panel Courtesy
U66 - Dual front & Rear Speakers,
VAN - Van Nuys
VK3 - License Plate Mounting Package
V73 - Vehicle Statement US/CAN
WS6 - Performance equipment
W63 - Option Group #2
W66 - Formula
YR1 - Seat - Front Custom
YS1 - Seat - Rear Custom
YT1 - Custom Build UP
YT9 - Fisher Furnished Parts
1SV - Special Vehicle Components of W66 Formula Package
11Q - Exterior Molding - White
18P - Charcoal Wheels
40U - White Upper Paint
6ZV - Front Left Spring
7VW - Front Right Spring
71A - Stripe - Orange/Silver/Black
8NL - Suspension Spring
82C - Gray Custom Interior
82I - Gray Interior
829 - Gray Seat Belts
87L - Lower Charcoal Secondary Color***
9NL - Suspension Spring
*** NOTE: 84L & 87L were both used in 1987, they are both the same color, but they changed RPO Half way through 1987
Old Jun 16, 2023 | 09:42 AM
  #146
chazman's Avatar
Axle/Gears: BW 3.45
C49 - Rear Defog
D81 - Aero Spoiler
D86 - 2 Tone Paint
GU5 - 3.23 axle
LG4 - 5.0L 4BBL
M39 - Manual Trans
NA5 - Fed Emissions
TR9 - Lamp Group
U21 - Gage Package
VAN - Van Nuys
W66 - Formula
82I - Gray Interior
Thanks!
No code that I can see for dealer order vs customer order.
Old Jun 16, 2023 | 12:29 PM
  #147
okfoz's Avatar
Z31 is the Identification Price Sheet Advance,
WS8 is Price Order Acknowledgement
WY1 is Dealer Protection
ZF7 Sales Processing Option #26
ZF9 Sales Processing Option
On my lists of all the RPO codes I do not see anything to distinguish between a Dealer Lot car and a Special Order. It might be WS8 (Price order Acknowledgement) but That is a guess.
Old Jun 16, 2023 | 02:10 PM
  #148
chazman's Avatar
Axle/Gears: BW 3.45
Thanks again. I can’t imagine a dealer deleting PW and PDL though.
Old Jun 17, 2023 | 12:52 AM
  #149
chazman's Avatar
Axle/Gears: BW 3.45
How many guys does it take to crack loose a rusted on distributor bolt which hasn't been touched since 1987?
4 guys, and 1 to 2 hours.All the swear words.
Old Jun 17, 2023 | 11:39 AM
  #150
DaveyDug's Avatar
Car: 1989 IROC
Engine: 5.7 TPI
Axle/Gears: 2.77 Posi
Yikes. Was it rusted in place or was it more of an accessibility issue?
Tell us more, starting with why you were trying to loosen the distributor bolt.
