140mph Speedo
Old Jun 7, 2023 | 01:42 PM
brks_rus's Avatar
140mph Speedo
Looking to settle a debate on a couple of questions regarding the 140 mph speedo in the third gens.
1) when was the first 140 mph speedo introduced?
2) in 1987 which engine options got the 140 vs. the 85 or 120?
Thanks.
Old Jun 7, 2023 | 04:58 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Re: 140mph Speedo
I never got into the exact specifications, BUT I know unless the aftermarket GM ones no 145 until mid year 86. I had an 85 with the GMPP 140 speedo with the older style needle.
From seeing them when I was younger, the TBI irocs got the 115.
I don't remember many later (after 88) having the 85?
Old Jun 7, 2023 | 05:03 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: 140mph Speedo
Would the 145 ever come with a cable drive for my 83?
Old Jun 7, 2023 | 06:34 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: 140mph Speedo
Late '86 according to Camaro The Third Generation by Michael Lamm.
Old Jun 7, 2023 | 06:39 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: 140mph Speedo
Camaro had cable drive speedos through '89.The '82 and '83 speedos had the trip odo reset button in different position than '84 and later.The info in reply #2 is what I know also: 145 speedo mid-1986 addition.
Old Jun 7, 2023 | 06:45 PM
Edwardgp's Avatar
Engine: 454-350
Re: 140mph Speedo
Thanks for the information, i will look around and see what is out there. Thanks again.....
Old Jun 7, 2023 | 07:37 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: 140mph Speedo
There was an over the counter version of a 140mph speedo available in 1982. Many pace car owners would swap to these to mimic the actual pace cars. The factory 145 speedo came in mid-1986. In 1987, if i remember correctly, the 145 speedo was installed in TPI engine models. I can't remember.
Old Jun 7, 2023 | 08:00 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Re: 140mph Speedo
Reagan got rid of the 85MPH speedo rule in 1982:Porsche and many other car brands upgraded their speedos for '82 while it took Detroit well into the mid 1980s to change up...Started seeing the 85 MPH speedos in some 1979 cars,was required for 1980 models...
Old Jun 7, 2023 | 08:21 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Re: 140mph Speedo
The replies seem to be about Camaro speedometers, and maybe that's what the OP was talking about, but he didn't say which, Camaros or Firebirds.
I was going to post a couple of links to some for the Camaro that are currently for sale, but so many came up that I'm just going to say to anyone interested in them, the internet. Both styles are out there and available: Ebay, Thirdgen Ranch...
Here's a currently active thread with a picture of the over the counter "Z28" speedometer that Scott was talking about. MPH only, no KPH. I installed one in my 1983 Z28 back in 83/84. This type would be better suited to the earlier Camaros than the factory 145 MPH speedo that came during the middle years.
1984 Z28 L69 - Third Generation F-Body Message Boards
Firebirds started getting 140 MPH electric speedometers in 1986, and they only featured MPH, no KPH, obviously not for export. 1987-1992 had 140 MPH (with KPH).
Edit: The OP said "third gens," but I overlooked his sig, which says IROC.
Old Jun 8, 2023 | 10:05 AM
ACebell's Avatar
Car: 1983 Camaro Z28
Engine: Originally LU5, but now Carb'd
Transmission: TH350
Axle/Gears: 323
Re: 140mph Speedo
My memory is a little foggy (come with age), but I remember my '85 Z28 (TPI) had the 85 MPH speedo. My best friend (still to this day, car is long gone) had an '87 Iroc with the 120 MPH speedo (305 TPI). He went down to the stealership, and bought the 140 MPH speedo shown in Saxondale's beautiful '84 (really nice car). This was BIG money for broke community college kids. We swapped out his 120 MPH to the 140 MPH speedo, and then swapped my 85 MPH speedo to the 120 MPH speedo, So the '87, 305 TPI (at least) got the 120 MPH speedo.
Old Jun 9, 2023 | 02:09 PM
nothingssafe's Avatar
Car: 86 TA
Re: 140mph Speedo
The performance versions (TPI cars and 5 speed L69 cars) received the 140 Speedo mid 86. The first run for the Trans Ams did not have the kph, it was added later in the 1986 model year. I had a late 86 Trans Am with a factory 140 Speedo with the kph that I swapped out for one without for a cleaner look. From what I've seen the 87+ cars only received the higher speedo for TPI cars, not the TBI equipped IROC/TA/Formula.
Old Jun 10, 2023 | 05:09 PM
brks_rus's Avatar
Re: 140mph Speedo
Great info. Thank you.
Old Jun 11, 2023 | 01:18 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Re: 140mph Speedo
i'm thinking that you also had to have a 350 to get 140mph speedo in addition to what was said above
Old Jun 11, 2023 | 02:23 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: 140mph Speedo
I'd like to get a 140 for mine, or even a 120...
Old Jun 11, 2023 | 07:46 PM
Saxondale's Avatar
Car: 1984 Z28
Engine: 305 HO
Transmission: 5 Speed
Axle/Gears: 3.23 Truetrac; was better w/ 3.73
Re: 140mph Speedo
More info on the early style 140 parts catalog version for Camaro. Needs an early lens because reset is at 10 o’clock. Needle style matches ‘82-84 gauges.
valicswarrior
Dec 25, 2010 08:58 PM
FireBirdKnight
Sep 20, 2007 05:42 PM
Diehard34
Interior Parts Wanted
May 19, 2006 10:42 AM
