1983 Daytona 500 pace car project build
Old Nov 14, 2025 | 05:58 AM
Jay-GTA's Avatar
last week I picked up the bird and hoping to bring it back to life.
a lady bought it back in 83 and kept it . It was basically stored unused in a garage since 2001. The oil change sticker says 2001 and matches milage so it’s due.
im in Canada so car is in metric kilometers
Old Nov 14, 2025 | 02:27 PM
Jay-GTA's Avatar
Re: 1983 Daytona 500 pace car project build
View this post on Instagram
https://www.facebook.com/share/r/188...ibextid=wwXIfr
this is picking up the car
Old Nov 17, 2025 | 02:46 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I love these cars.
That example looks pretty solid from that one photo.
Old Nov 17, 2025 | 08:55 PM
Jay-GTA's Avatar
Thanks. Right now I bought it not starting and stuck in park.
when I got it home I realized the c clip had fallen off the shift linkage
Old Nov 18, 2025 | 10:20 AM
ratfink6923's Avatar
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
There's a bushing missing from the end of the cable, not a c clip
Old Nov 18, 2025 | 12:18 PM
Jay-GTA's Avatar
Have a picture of what it looks like?
Old Nov 18, 2025 | 06:40 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
What drivetrain does your car have? There has been several documented Canadian/Export spec '83 DT500 cars
that have surfaced with the open-loop non-ECM controlled LG4 carb 305/TH200C 3-speed automatic.
This drivetrain combo isn't on the normal DT500 order form and wasn't thought to exist until about 15 years ago.
Old Nov 18, 2025 | 07:45 PM
Jay-GTA's Avatar
Oh that’s very interesting. My 85 was a strange no computer no smog pump lg4 car.
my 83 daytona500 is crossfire with overdrive
I just pulled the gas tank today. I need to replace the fuel pump. I’m replacing the sending unit just to be safe .
Old Nov 20, 2025 | 08:27 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Working in the "big garage" I see.
If the sender is clean and ohms correctly through the sweep, I'd continue to run it. It really stinks when a new replacement part doesn't last as long as the original would have if it was left in place.
Old Nov 20, 2025 | 08:29 PM
Jay-GTA's Avatar
My gas guage is pegged past full…..?
not sure why it’s doing that.
i figured a new sending unit would fix issue?
Old Nov 20, 2025 | 08:36 PM
Engine: that I like
Could be the sender, yeah. But only testing can verify that. With the ignition on, ground out the sender wire to the body and the gauge should read empty. If it doesn't, the sender won't fix your issue.
Burton5251
Apr 9, 2026 03:43 PM
gt4373
Sep 17, 2025 11:06 PM
mosca
Apr 19, 2025 11:07 AM
chazman
May 24, 2021 04:26 PM
jraider66
Fabrication
Feb 1, 2021 03:15 PM
