RPO 05A defined?
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Transmission: T-5 5-Speed Manual
RPO 05A defined?
Using this board, the RPO decoder & the Camaro White book I was able to define most of my RPO codes.
One RPO that is left unanswered is 05A. The nearest I can figure, it is the code for secondary colored headlight buckets. Does anyone have this code that also has different colored headlight buckets?
FWIW my car is two-tone Black & Gunmetal grey.... the buckets were originally gunmetal grey along with the rocker panels.
-Don
-Don
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Well there you go then! I knew it had something to do with the paint
So what is the RPO for accent colored headlight buckets?
dimented24x7
Sep 17, 2015 06:58 AM
