Last '92 350 Trans Am
Old Nov 27, 2005 | 01:11 AM
David M's Avatar
Car: '84 Z28
Engine: L69
O.K. here is the last post for the '92 Pontiac F-car. I finish it up with the last 350 Trans Am.
1G2FW2387NL227461 Built Aug 26, 1992
AAA AJ3 AQ9 AU3 A31 A90 BC8 B2L B84 C49 C60 DC4 DG7 D42 D5X D8I E5Z E9Z FE2 GU5 G80 IL2 J65 KC4 K34 K68 L98 MD8 MX0 NA5 NP5 N10 N64 PW7 QLC R6P T93 T96 UB3 UQ1 U1A U62 U75 VAN V73 WS4 WS6 Y84 1SA 45Q 45U 52P 6ZX 64I 642 649 7ZX 8NL 9NL
Delivering dealer: Pontiac- GMC Division
P.O. Box 50267
Atlanta, GA 30302-0267
Ship to info: Wynn Pontiac-Olsmobile-Buick-GMC Truck
P.O. Box 789
Cartersville, GA 30120-0789
Delivery date: 9-24-1992
Invoice date: 12-11-1992
Old Nov 27, 2005 | 11:36 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
That one was a GTA also, it has the Y84 RPO code.
1: AAA : 4-WAY MANUAL SEAT ADJUSTER
2: AJ3 : RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
3: AQ9 : SEAT, FRT BKT PASS DRIVER RECL
4: AU3 : LOCK CONTROL, SIDE DR, ELEC
5: A31 : WINDOW, POWER OPERATED, SIDE
6: A90 : LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
7: BC8 : ORNAMENTATION, INTR, DR MAP POCKETS
8: B2L is not in the Data Base
9: B84 : ORNAMENTATION, EXTR MLDG, B0DY SIDE
10: C49 : DEFOGGER, RR WINDOW, ELECTRIC
11: C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
12: DC4 : MIRROR I/S, R/V, TILT, DUAL READING LAMPS
13: DG7 : MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED
14: D42 : SHADE, RR COMPT SECURITY
15: D5X : GEAR, SPEEDO DRIVEN
16: D8I : SENSOR, VEH SPD
17: E5Z : SPEEDOMETER ADAPTER (DELETE)
18: E9Z : SPEEDOMETER KEY (DELETE)
19: FE2 : SUSPENSION SYSTEM, RIDE HANDLING
20: GU5 : AXLE REAR, 3.23 RATIO
21: G80 : AXLE POSITRACTION, LIMITED SLIP
22: IL2 : TRIM- INTERIOR DESIGN
23: J65 : BRAKE SYSTEM, PWR, FRT & RR DISC
24: KC4 : COOLING SYSTEM, ENG OIL
25: K34 : CRUISE CONTROL, AUT0MATIC, ELECTRONIC
26: K68 : GENERATOR,105 AMP
27: L98 : 5.7 LITER V8 TPI ENGINE
28: MD8 : TRANSMISSION, AUTO 4 SPD, THM 700 R4
29: MX0 is not in the Data Base
30: NA5 : EMISSION SYSTEM, FEDERAL, TIER O
31: NP5 : LEATHER WRAPPED, STEERING WHEEL AND SHIFT ****
32: N10 : EXHAUST SYSTEM DUAL
33: N64 : WHEEL & TIRE,SPARE, SPACE SAVER, ALUMINUM
34: PW7 : WHEEL, 16 X 8, ALUMINUM, DIAMOND SPOKE
35: QLC : TIRE ALL, P245/50ZR16/N BL R/PE ST TL HW4
36: R6P is not in the Data Base
37: T93 : TAIL & STOP LAMP, SMOKED
38: T96 : LAMP, FOG
39: UB3 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
40: UQ1 : RADIO PROVISIONS, FOR STEREO
41: U1A : RADIO, AM STEREO-FM STEREO, SEEK/SCAN, COMPACT
42: U62 : SPEAKER SYSTEM, DUAL COAXIAL
43: U75 : ANTENNA, POWER, RADIO
44: VAN : ASSEMBLY PLANT, VAN NUYS, CA
45: V73 : ANTENNA, FIXED
46: WS4 : MODEL CONVERSION, TRANS AM
47: WS6 : PERFORMANCE PACKAGE, SPECIAL
48: Y84 : MERCHANDISED PKG, GTA, TRANS AM
49: 1SA : Option Package 01
50: 45Q : MOLDING COLOR, MED GREEN MET (91)
51: 45U : PRIMARY COLOR, EXTERIOR, MED GREEN MET (91)
52: 52P : WHEEL COLOR, GOLD MET (91)
53: 6ZX : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
54: 64I : INTERIOR TRIM, LIGHT BEIGE (I) (92)
55: 642 : TRIM COMBINATION, LEATHER, LT BEIGE (2) (92)
56: 649 : SEAT BELT COLOR, LIGHT BEIGE (9) (92)
57: 7ZX : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
58: 8NL : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
59: 9NL : COMPUTER SELECTED REAR RIGHTHAND SPRING
Old Nov 29, 2005 | 09:15 PM
p.haze92's Avatar
I thought all of the GTA's and T/A's had JG1 aluminum shaft?
Old Nov 29, 2005 | 09:34 PM
SLPhawk95's Avatar
Its still on the road, check it out!!!! Ran a carfax.....
12/9/1992 SOUTHEASTERN REGION, 3481 Auto Auction REPORTED AT AUTO AUCTION
2/28/1996 SOUTHEASTERN REGION, 44016 Auto Auction REPORTED AT AUTO AUCTION
2/28/1996 SOUTHEASTERN REGION, 44016 Auto Auction AUCTION ANNOUNCED AS FLEET/LEASE
4/23/1996 LOMBARD, IL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
5/2/1996 LOMBARD, IL 44258 Motor Vehicle Dept. TITLE (Title# T6123505048)
4/7/1997 LOMBARD, IL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
4/17/1998 LOMBARD, IL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
3/19/1999 LOMBARD, IL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
4/12/2000 LOMBARD, IL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
8/11/2000 ADDISON, IL 56000 State Agency FAILED EMISSION INSPECTION
8/24/2000 WHEELING, IL State Agency FAILED EMISSION INSPECTION
9/8/2000 ADDISON, IL State Agency PASSED EMISSION INSPECTION
4/2/2001 LOMBARD, IL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
2/25/2002 LOMBARD, IL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
8/27/2002 WHEELING, IL 59000 State Agency FAILED EMISSION INSPECTION
9/17/2002 ADDISON, IL State Agency PASSED EMISSION INSPECTION
2/26/2003 LOMBARD, IL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
3/10/2004 LOMBARD, IL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
9/21/2004 LINCOLNSHIRE, IL 61000 Independent Emission Source PASSED EMISSION INSPECTION
4/22/2005 LOMBARD, IL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
Old Nov 30, 2005 | 11:14 AM
p.haze92's Avatar
IL its whole life. Must be RUSTY.
theshackle
Sep 17, 2020 08:26 AM
camaro71633
Sep 1, 2015 10:24 AM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
milk
Aug 10, 2015 06:26 PM
