anyone know what this paper is?
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i found it in my car this morning... it was halfway under the carpet, under the radio/center console area.
im assuming its from some engine test or something, but it would be cool if anyone knew for sure.
Car: 1987 Pontiac Trans Am
Engine: 305 LB9 Tuned Port Injection
Transmission: 700-R4 Automatic
Axle/Gears: Saginaw 10 bolt 2.73 posi
A31 refers to powers windows, and L03 refers to a 305 TBI engine. Perhaps its a quality check from the line???
Car: 1997 S10
Engine: 4-Cyl 2.2 Liter
Transmission: Automatic
i have seen thoes on here before there a cool pice of history to have. I think 87TAairlineyard is right. If i rember right they check the engine and stuff right before it comes off the line and if the stuff works ok you get one of thoes.
Car: 1997 S10
well i did some searching around here you go
https://www.thirdgen.org/forums/hist...mbly+line+test
hope this helps
hope this helps
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
It states right on it "IP test" Its the report of the Istrument Panel Test that was performed in the Assy plant OR it was from a test performed at the manufacturer.
John
John
