Electic contacts for thrid brake light
Old May 24, 2006 | 09:20 AM
mcgyvr63's Avatar
Car: 1988 GTA - hard top
Engine: 5.7
I am looking for both electic contacts (upper - located on the hatch to the left of the striker & lower - located to the left of the pull down unit) for the thrid brake light of an 88 GTA.
Current ones are getting worned out from the constant rising and lowering of the rear hatch.
Thanks.
Old May 24, 2006 | 09:50 AM
myfast3rdgen's Avatar
Car: Trans Am
Engine: 305 to 350 to 383 to BOOM!!!
Transmission: 5-speed
Axle/Gears: 3.73 10-bolt
I think it might have a set of them lying around...Although I had the same problem and I could never get mind to sit right. I had to take foil and place it in the contact in order for it to work....I have it at my grage and I won't be there untill saturday or sunday, if i find, i'll send you a PM,
But personally I would just try the foil thing...I also saw something take two springs and place them in the contacts. He drilled holes in the metal and screwd the springs in, then used a little lead to keep it in place, and he said that worked just fine, and it didn't even look that tackie
Old May 24, 2006 | 03:53 PM
dave mc's Avatar
Car: 87gta 88gta 88marovert
I have an 89 fromula I'm parting out. have both of them 15.00 with shipping can get pics if you need them?
Old May 25, 2006 | 07:46 AM
dave mc's Avatar
I also have a bottom contact in gray but it has a loot of where.
Old May 26, 2006 | 01:12 AM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
i got that as well for 20 dollars but closer to NY its out of a 87 firebird
Old May 26, 2006 | 06:42 AM
mcgyvr63's Avatar
Engine: 5.7
Got pics?
Old May 27, 2006 | 01:09 AM
Car: 1985 TransAm
Engine: 5.0L TPI
looks the same as daves except the plastic is grey contacts are good condition it is disconnected from my car since i bypassed it...
Vintageracer
Jan 10, 2020 05:33 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
