ignition key lock screw and buzzer contact switch
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
edit found a screw around here finally but not a contact switch, guess no one has anything
delete please thanks
i need the correct ignition lock retainer screw from the column for my 82 trans am, i also need the little contact switch that pops into the hole in the column for the ignition key lock- it is white plastic and square or rectangle shaped and has two copper colored contacts coming out of it that touch together at the ends of them
can anyone help me out, that would be great, so i can get my column back together so i can get my car out of the storage and get the engine in ASAP
how much to 62656
thanks
how much to 62656
thanks
1992 Trans Am
May 10, 2023 07:19 PM
