factory gm floormats needed grey
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
looking for a pair of the grey front dvr and pssgr oem floormats new or good shape used no rips tears or heavy stains i want the origional fit ones not universal fit ones from the store
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Re: factory gm floormats needed grey
Try www.moderndaymuscle.com
I was surfing there this morning and they have oem mats....
Car: 1985 TransAm
Engine: 5.0L TPI
i looked at them they look just the same as the ones in the store but with a gm emblem
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
i think classic industries had them i'll have to check.
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I don't know if you would consider rubber but I bought the black rubber ones from Moder Day Muscle and they are excellent. They have the grey Camaro logo in the lower corner where it is the first thing you see when you open the door. Very thick and extremley well made. I too wanted the carpet GM one but I actually think these are way better. Also they are cut to fit the entire floor so no moving or sliding. They are so big that you can't see any of the carpet either which makes them perfect if your capet is damaged.
Car: 1985 TransAm
Engine: 5.0L TPI
they are exactly what i need but i perfer oem carpet type mats w/ gm logo trying to keep it origional
1992 Trans Am
May 10, 2023 07:19 PM
