T-Top pin holder
Car: 85 Iroc-Z
Engine: 383, Vortech SQ
Axle/Gears: Stock 7.5 w/ shafts, 3:73
T-Top pin holder
Guy's,
I'm looking for the wider 2 plastice holder for the T-Top pins. These are the plastic peices where the T-Tops lock into. They bolt to the car and when you lock the T-tops in the pins get inserted in them. I bought a pair of Lexan tops and they need the larger pin holders. Need all 4. Let me know. Thanks
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: T-Top pin holder
You don't need them....... I've had Lexan "large pin" T-Tops installed in all my 86 and earlier "small pin" T-Top cars. If your lexan tops didn't fit when you tried to put them on - your existing pin brackets just need to be adjusted.
Car: 85 Iroc-Z
I'll try to see if I can re-adjust the locking bar to see if it lines up. The pins on these T-Tops have a plastice type sleeve around the pin. I looked at them breifly, but didn't think they would work. I'll try & let you know. If they don't what do you want for the 4 pin holders?
I didn't think they would work either - then I bought a set of pin holders from a Lexan T-Top car and they were exactly the same as the ones I already had on my 84.
Hope this helps !
Hope this helps !
Thirdgen89GTA
Nov 26, 2015 11:04 PM
