91 or 92 guage cluster/camaro
Old Jul 21, 2008 | 10:45 PM
fbirdroller's Avatar
Car: 1986 camaro z28
Engine: vortec 5.7
i need an electronic speedo for in my 86 z28 and i was told that 91 and 92 had them so i am looking for the guage cluster that i can hook up the speedo properly with a 4l60e
Old Jul 21, 2008 | 11:11 PM
Dokken10's Avatar
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
Re: 91 or 92 guage cluster/camaro
90-92 Camaro clusters will not fit without changing the whole dash and wiring.
88-89 Camaro clusters should fit your 86 and are electronic speedo.
You really need a 4L60 or 700R4.
The E means it is controlled electronically NOT just the speedo
You can remove the VSS and put in a cable drive unit in the tranny and not have to change your speedo or cluster. Thats the cheapest and easiest way to make it work.
sheachopper
Jul 31, 2019 11:27 AM
tmellott89
Oct 14, 2015 02:06 PM
