seats, carpet, instrument cluster
Want a title? Post!
Car: 1989 iroc z
Engine: 383 stroker
Transmission: 700r with shift kit
Axle/Gears: 410 pos.
hey guys my 89 iroc has a bad cluster, is missing carpet and the seats are from a 91 z28, their grey in color but need to be recovered. i would like to trade my seats for iroc seats and need help figuring out why only my tach works and nothing else works right, the oil pressure jumps all over the place, the fuel jumps when you hit bumps and the speedo has never worked..i need the computer side of the wiring harness to make the speedo work but no one has that around here or a computer for an iroc i need the harness and computer for an iroc that was carbed mine was originally tpi 5.7 but is now carbed 5.7 so please help
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Re: seats, carpet, instrument cluster
sounds like a bad ground I had a problem like that on my olds it was the ground the lights would and i think the speedometer works off a cable in 89 not sure I know 91 is electronic
Want a title? Post!
Car: 1989 iroc z
Engine: 383 stroker
im not sure about grounds i only have half the wiring harness in the car, just what it needed to run. yes i am looking for grey carpet i have the trunk part i just need the cab part
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Have you checked to see if you have a speedo cable hooked up to the back of the cluster? I've got a 145 mph V8 cluster that is cable driven I could part with
Want a title? Post!
Car: 1989 iroc z
Engine: 383 stroker
yea it is but my car has the cable speedo and digital trans so id need the digital setup or change my whole trans out
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
What might help you out is an mid eighties ThirdGen engine harness. From 82-87 the engine harness was seperate from the ECM harness and after 87 they were merged into 1 huge harness. A ENGINE harness from an 84-87 would be best for you if your running a carb. (82-83 Engine harness have incompatable wiper motor connections. The wiper wiring might still need to get spliced because the 84-87 wiper is different from the 88-92 style - but it would match better than 82-83 wiring ! ) The 84-87 engein harness has the wiring for the Alt, Distrib, Starter, Wipers & all Gauges - everything you "need".
When it comes to your speedo,... you don't need to swap the transmission & You can't install a 90-92 cluster into an 89. You'll need to install a speedo cable ( if not already in the engine bay, ) and you will have to replaced the electric speed sensor in the tranny tailshaft to the cable type speed sensor. Just be sure that you use the correct cable type sensor and plastic speedo gears when you swap so the speedo remains accurate when the cable is re-connected. The speedo gears in the replacement tranny can't be trusted - VERIFY the gear ratio IN THE REAR END before getting a replacement speed sending unit and speedo gears !
Are you still running an electric fan ???
