Wanted power steering pump bracket & pump whole unit.
Old Aug 9, 2012 | 05:05 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Well was driving down the road today and i felt something was not right, then AC was not cold, no power steering. i just wanted to make it home. drove the 5 minutes and got home lifted the hood and the serpentine belt gone! The bracket of power steering pump broke in half and the real bracket bolt holes broke off. What the h**L so did the bracket break first causing belt to come off or did the belt break and cause the braket to brake?? Weird But any way i need a bracket for a 2.8 but if you have the whole unit as seen in picture i have added would be interested in that.
Of corse this is not the right one for my car. Just a example of what i would buy from someone that has a unit with the brakets, pump, high presure hose for power steering.
Would be nice if you had some pictures, and price for me. If you just have the brakets front & rear, would buy that too. I have a V6 2.8 motor.
Thanks guys
Old Aug 9, 2012 | 06:06 PM
Engine: MPFI
Re: Wanted power steering pump bracket & pump whole unit.
Bump, really need to get this fixed. Anyone? Maybe a junk yard find.
Old Aug 9, 2012 | 06:33 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Think I have one but will have to find it. Pretty sure there's no pump. It's kind of heavy anyway so you might just get new? Are you sure there's anything wrong with the pump or line? And is your pulley still good? Need any of the bolts? Just curious, will LYK when I find it what all I have, Henry
Old Aug 9, 2012 | 10:44 PM
Engine: MPFI
No i probably don't need the pump or line or pulley, just thought it would be easier changing the whole thing. If you have the front and rear brackets that will fit a 89 V6 2.8 that would work.
Thanks for looking, i appreciate it.
Old Aug 10, 2012 | 03:35 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Hi found the two brackets and the pulley in good shape. PM or email me your email address for pics and other info, Henry
Old Aug 13, 2012 | 12:07 AM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
I have na powwr steering pump from a 92 is the same as a 89 2.8 PM me your email for pics
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
TreDeClaw
Aug 14, 2015 06:58 PM
