[GA] need wiring harness for a non efi firebird
Car: 1990 formula 350
Engine: 383 stroker
im looking for a wiring harness for my 1990 firebird the tbi was taken out and replaced with a carb the the owner before me hacked up the main wiring harness trying to get rid of the extra wires for the tbi and ruined everything (headlights, blinkers tack, ignition,.........) any thing will help. I have already a stand alone engine management system so everything else please and thank you. or if you could head me in the right direction for what I need
Engine: 383 stroker
Re: need wiring harness for a non efi firebird
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Main power to fusebox and Tach signal is on the engine harness and headlights are on the headlight harness.
On a 90,..... your asking for all teh wiring under the hood.
I like headlights tach and power supply to the main fuse block and the two relays by the brake booster and that should be all
