[TX] Headlight switch mounting nut
Car: 1988 IROC-Z
Hi there -- yes, there's one on Ebay.. but, it's 21 dollars. Looking for the plastic screw that holds the switch in place. Ruined mine when I took the dash out.
thx
j
thx
j
Car: 91 Camaro RS
Engine: 305 TPI conversion.
Car: 1989 Iroc hardtop
Engine: 5.7
Re: Headlight switch mounting nut
I went to ACE hardware, and took the headlight switch in with me. I found a gentleman in the plumbing department that helped me find a brass compression fitting that screwed into the switch nicely. I had to drill the center of the fitting out just a bit to allow for the push/pull **** to pass through easily, plus I had to get a couple of small washers, but it worked quite nicely.
The guy in the plumbing dept. didn't even charge me for it. He said as far as he was concerned I brought it in with me. lol. I did pay like 45 cents for the two washers. Hope this helps.
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
