looking for rear seat side panels plastic flame red
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
looking for the left and right side plastic panels that have the wheel well hump molded in them...in flame red.
now for the good news it's ok if some of its broken..as im only needing the wheel well hump part of the plastic piece..from ea side.
now for the sad part.. i will need just the part with the wheel well hump. so it can be cut down to make shipping easy.
this is going in ontop of mine to fill in around part of my roll bar. to make a better fit..(holes are cut 2 1/4 wide) my bar is 1 3/4 wide. oops. so i want to make a better fit by cuting it out and laying over the lager hole...
might even use any colore. i could dye it/paint to match.. just need the plastic the has that contour. of the wheel well..
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
Re: looking for rear seat side panels plastic flame red
I have some dark red ones Not sure if that will work for you
I will try and get pics posted this weekend having surgery tomorrow
Need a price... can get started after that.
thank you for your reply..
pic is close.(wrong part)...but need the part that has the wheel well hump in it... one side is a big piece of plastic.. the other side is smaller..but both have the wheel well hump...
after paying for the parts ill show/send info on what part i need Cut out of them....as im only using part of the plastic..
this will help in the shipping side as the parts will be smaller when done....or i can just cut them...
parts info:
the part with the wheel well hump also has the back seat latch hole in it(seat latch holds seat in the up/lock mode)
and has the cut out for the rear hatch struts in it...and rear speaker vents.
parts info:
1992 Trans Am
May 10, 2023 07:19 PM
