[NC] Factory rear 10 ohm 6x9 delco speaker
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
All of my speakers are original and work great except one, so I am looking to replace it with another factory one.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Factory rear 10 ohm 6x9 delco speaker
The best thing for you to do is take the P/N off the back and call a GM dealer to see if there still available and if they are I would order a new set from GM Parts Cheap - OEM Genuine at Wholesale or GM Parts Direct: Your direct source for Genuine GM Parts.I have a set of 6x9s rears out of a 88 TA,but their not 10 ohms there 4.
Car: 1987 Iroc
Axle/Gears: 3.50 9"
true. I hate they are 10 ohm. The 10 year younger self would already have 2 aftermarket 6x9s in there.
LOL
LOL
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Yep, new would be best imo. You never know what you're getting with used speakers. That said, if you're not too concerned about having exact stock, the 6x9's I pulled from my old '96 Bonneville are also 10ohm. They don't look the same and it looks like the connector is different. There should be a bunch of those cars at the local junk yards where you are.
Car: 1987 Iroc
Axle/Gears: 3.50 9"
If I'm replacing them with something different I'd hate to cut the stock wiring to do it and not upgrade to an aftermarket speaker....... BUT If I go aftermarket I will most likely need to upgrade my radio to compensate or risk messing up my factory radio....
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Have a pic of the plug?
It is 10 ohm, correct?
eightsixseven
Dec 16, 2024 01:50 PM
ambainb
Apr 25, 2016 09:21 PM
sailtexas186548
Jan 19, 2016 12:21 PM
