Shift Boot Dimensions?
Old Mar 24, 2006 | 01:21 AM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Does anyone have some fabric dimensions for the manual shift boot?
I don't see any boots out there I like, so I thought I'd sew one together. Thought I'd ask and see if anyone has some specs before I try to make things fit by guessing.
-Paul
Old Mar 24, 2006 | 09:09 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check the following link:
http://web.camaross.com/forums/showt...t=leather+boot
JamesC
Old Mar 24, 2006 | 01:21 PM
Originally Posted by JamesC
Thanks for the link.... but this is hidious!
Old Mar 24, 2006 | 01:30 PM
JamesC's Avatar
I'm currently using one a found in a bone yard. It's first rate (though I doubt I'd find another quite as good).
JamesC
Old Mar 24, 2006 | 01:33 PM
mr_han_solo's Avatar
Car: 1986 Camaro Coupe
Engine: 2.8L V6
I made my own, note thats its for an auto. I now have a different shift ****, and I think it looks 100% better. I'm sure making your own boot would be loads easier for a manual.
Han
Old Mar 24, 2006 | 03:42 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
I used to make a few boots for the auto firebird, it was just a stock replacement. I once made a manual boot for someone who had a ripped one but it didnt come out as well as the autos did, the difference between the manual and automatics are besides the obvious size, the manual one has 4 sides and the auto only has 2. This made it very difficult for sewing the manual because the circle at the top had to be the correct size for the shifter and finishing off the 4th side became complicated, you will see what i am talking about when you try it. I dont have the dimensions anymore nor do i have a 3rd gen centerconsole anymore so i couldent even tell you, I now have one from a 99TA and i like the look alot better.
Good Luck,
Dennis
Old Mar 24, 2006 | 04:35 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
im looking to make a custom shift boot for my mega concle shifter any one have info fill me in {its an auto}
Old Mar 24, 2006 | 07:14 PM
MD88IROC's Avatar
Car: 88 IROC
Transmission: 5 speed
Axle/Gears: G92
How about taking apart your old one and copying the panels. I could use a new one too. Maybe you could start a side line here. If you don't have an old one to copy, I could take mine out...I do have another used one I am going to put in anyway.
Old Mar 25, 2006 | 11:31 AM
Don't have one to copy. About to finish up my T56 swap. Just waiting for the clutch set to arrive.
Old Mar 25, 2006 | 11:44 AM
MD88IROC's Avatar
Car: 88 IROC
Axle/Gears: G92
Are you interested in mine to use as a pattern ??? You can rip the sewing out and copy the panels. I don't need it back, but would be interested in having you make me one too, if it turns out good.
Old May 18, 2006 | 06:37 PM
Finally getting around to posting a picture. Here is the boot I made, based on MD88's template.
It fit a stock height stick perfect. I cut mine down and it's a little low but stilll looks good. I might modify the design a bit to have it not sink so much below the plate, but I'm in the process of putting Autometer gauges in right now so it will wait.
Thanks again MD88! Worked out perfect!
Old May 20, 2006 | 01:54 PM
91sleeperRS's Avatar
Car: Sold my Thirdgens, want another one
Engine: L98/TPI
Transmission: 5-speed
Axle/Gears: 3.45
believe it or not, i took mine out of the junkyard off of a 80s mustang. it worked okay with a little modification. i thought it was pretty ironic.
Old May 22, 2006 | 09:54 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
i have one for my automatic that i pulled from a grandprix with the shifter **** as well i think it looks pretty good but i mounted the boot on top of the plate. if i decide i dont like it like that ill go get some plexiglass and make a whole shiftplate. ill get a pic tomaro maybe.
Old May 23, 2006 | 07:22 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I have a leather boot that I bought on Ebay for around $25. For the money I'm happy, but it'll get upgraded when I get the money to have a real upholstery shop redo it. The leather is very nice, but is a different grain than the original, and it seems like there's too much leather there, like the car the guy originally designed it for had a much taller shifter.
But for the money, I don't have any complaints.
I don't have any great pics, but here are a couple:
Old May 25, 2006 | 01:25 PM
Car: 88 IROC
heres a pic of the boot i was talking about. it actually looks good in person, in the pics the grey looks very very grey but actually it is a dark grey. it probably wont stay like this for long i want a megashifter or something.
Attached Thumbnails Shift Boot Dimensions?-img_0100.jpg   Shift Boot Dimensions?-img_0101.jpg
Old May 25, 2006 | 01:39 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
just out of curiosity, below the fabric/leather boot, is there supposed to be a rubber boot, that basically covers the hole in the floor boards? Or is that just specific to my hurst shifter?
I left mine out since it was pretty shredded, and I think i'll be getting more road noise... is this a common piece as well?
Old May 25, 2006 | 02:42 PM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
you'll get more then road noise.. dirt, water.. small animals.. :P
Old May 25, 2006 | 02:46 PM
Sonix's Avatar
Car: 1982 Trans-Am
.... ok, so that rubber "stepped" boot is specific to shifter, or tranny or car?
Where can I get one that will fit right? The one in there had 6 holes I think, and only 2 lined up, and it was *very* chewed up, that's why I left the tattered remains out...
Old May 25, 2006 | 02:55 PM
dr1's Avatar
dr1
Engine: 305 TBI
junkyard, or a new aftermarket one (i suppose they could still be avail thru gm but doubt it)
ive seen 2 different stock boots, one for the rubber bushed/filled shifter and one for a solid shifter that im using now.. difference is in the size of the opening for the shifter itself
it doesnt create an amazing seal or anything, so even a tattered and beaten one will be better then nothing.. the tranny and road noise will be quite loud without it though
Old May 25, 2006 | 03:10 PM
Sonix's Avatar
Car: 1982 Trans-Am
oh yea, I know that. I'm running open headers and no boot, good god...
I threw out the old one, it was beat up. I'll grab a hurst one thats meant for this... Or measure the hole spacing or something..
Old May 26, 2006 | 12:35 AM
The factory T5 one for our cars fit both the T56 stock shifter, and PRO 5.0.
For the stock shifter, there is a rubber grommet about 1.25" in dia that would fit around the shifter stick to seal the rubber boot.
Old Jul 25, 2006 | 09:22 PM
82 Pace z28's Avatar
Car: 82 Z28 Pace Car Edition restoration
Engine: 5.7l
Transmission: t56
Axle/Gears: 3.23 open drum (not 4 long)
Hey there,
What clutch set up did you get? I need one for an LT1 t56 and a 74 350 (2 piece) Any idea on the dimensions for the one I need>> Thanks
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Gordonr1973
Sep 29, 2015 11:59 AM
