Man, Have I screwed up my odometer!
Old Jul 7, 2006 | 06:41 PM
senorcalvo's Avatar
Help!
A simple repair job has blown up in my face! I removed my instrument cluster to fix a non-functioning trip odometer(the classic j hooks breaking off problem) and when I put everyting back together my odometer had somehow rolled forward 150000 miles! I took it back out and tried to reset the numbers to their correct positions but no dice. In addition to that, it looks like a small plastic piece with notches in it that went behind the odometer has come out and I honestly do not know what function it serves but I'm sure it ties into my numbers rolling forward. I have spent 2 days trying to figure this one out-can anyone help that has experience with this sort of thing in speedometers?
What a dumbass I am-I should've just left well enough alone!
Mike
Old Jul 7, 2006 | 08:27 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
Thats easy. Just jack up the back of the car, put it in reverse and put a brick on the gas pedal. Also make sure the back end of your car is facing a bay window about 30ft off the ground. Didnt Ferris Bueler teach you anything?
Old Jul 7, 2006 | 08:43 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Thanks, I needed a good laugh
Seriously, I don't think it can be fixed. I have looked at my rollers and I wouldn't attempt to try to alter them Looks like you might be better off looking for a new speedo with the approximate mileage you had.
Old Jul 7, 2006 | 09:11 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
"In addition to that, it looks like a small plastic piece with notches in it that went behind the odometer has come out and I honestly do not know what function it serves but I'm sure it ties into my numbers rolling forward."
I believe that is the tamper thing. If an odometer has been tampered with, those things will show up telling you that the odometer has been tampered with.
Old Jul 7, 2006 | 11:44 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
just go to a pick and pull place and get another one??? thats what i did and just set the miles to my old on. Problem fixed
Old Jul 8, 2006 | 01:20 AM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
i have false mileage on mine too as i had to replace my whole cluster.
but whocares caz im not gonna sale my car,
so nobody need to know my real mileage..
just gotta know how much i drove so i can change oil on time
LT1Formula
Oct 8, 2015 08:34 PM
