Instrument panel upgrade help
Old Jul 8, 2006 | 01:06 AM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
I been trying to locate a good set of white overlays for my gauges and cant seem to find a good place to look?..plus I also cant find the correct bulbs for the lighting.The current ones are a 194LL(long life) and no local auto store stocks them.The bulbs are not removeable from the sockets,you have to purchase the whole socket bulb assembly.
Where can I find these items and has anybody replaced these with LED lights? Shoot me some input.
Second ,can anybody tell me the stock wattage of the instrument lights?
Old Jul 8, 2006 | 02:08 PM
Vaneat-91RS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
Well, I'm not sure about the rest, but the bulb/socket assembly is actually a PC194 or GM part#25089350. Your local GM dealer should have them or be able to obtain them within a day or so. Not sure about the wattage.
Old Jul 8, 2006 | 02:21 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
The white overlays are all over e-bay.
Old Jul 8, 2006 | 02:28 PM
Aerosmith's Avatar
Car: 1982 Camaro, 1985 Z28
Engine: 383, 305
Transmission: TH350, T-5
194 bulbs from any auto part store or WalMart is the same just not the heavy duty filiment like the long life ones. The factory put in regular bulbs not long life. The LL bulbs should not be permanent in the sockets unless someone glued them in. If tou need sockets they are in every GM car in the junk yard.
Old Jul 8, 2006 | 02:58 PM
jstrdn90rs's Avatar
Thanks guys...reason I ask cause I pulled off the dash and two of the bulbs were burned out and the bulbs where locked in ..not removeable from the sockets.I broke them out and installed some regular 194 and those worked a while and now those burned out.So I am just trying to figure out if I have a problem other then bulbs..thought that maybe the 194's wont work cause of the wattage or ?..I went to auto zone and the sockets are smaller then the ones they had on the shelve.I was told by auto zone/pep boys rep's that it took that bulb 194LL and they didnt have none.
And ya I seen those overlays on Ebay... have anybody used them?..want to know if there are of good quality..I dont want some Chinese looking stuff on my dash that will start to peel?
Old Jul 8, 2006 | 04:40 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
If by chance you can't find any bulbs I have a small bag of them.
Old Jul 8, 2006 | 11:46 PM
Aerosmith's Avatar
Engine: 383, 305
I don't know about the overlays, I fabbed a custom guage panel with Autometer Ultra-lite guages in it.
Old Jul 9, 2006 | 12:20 AM
jstrdn90rs's Avatar
Thanks again..I'll keep that in mine 82 Iron duke..I see what I can dig up.I'll try the dealer this Monday and go from there.
Old Jul 11, 2006 | 02:56 PM
jstrdn90rs's Avatar
I hit another parts store today and they didnt have them and told me to go to the dealer.So I went to the dealer and they told me they need a number off the back of the socket.He also said it wasnt a 194 bulb..and to top it off he said they didnt have any.He asked me the engine size ,and that stikes me as being odd?..is there a difference in the v6 and v8 dash bulbs?So in other words I have to remove the dash ,and check the numbers and put it back together cause its going to take a few days to get them.Just thought I'd post this... case someone else runs across this problem.What upsets me is its not like this car is 2 years old its 16...you would think they would have these bulbs stocked.
Old Jul 11, 2006 | 03:40 PM
jstrdn90rs's Avatar
Okay,tore apart the dash..and both people are right..does take PC194 and PC161 bulb/socket assemblies.I had to break out the bulbs cause they are permanent in the socket and installed a 194 bulb.I thought they were blown but they just a bad connection.So am good ,no need to order nothing.
Old Jul 12, 2006 | 11:08 AM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I bought these plastic assemblies the fit the dash and let you replace the bulb with a standard 194 bulb. So what I did was use these and put 194 LED lights in place of the bulbs. When I get home from work, I'll take a pic so you can see what I'm talkn about.
Old Jul 12, 2006 | 11:58 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Those bulbs must have been glued in, all of the socket assemblies from four different year dashes I was able to pull the bulbs right out of them.
Old Jul 12, 2006 | 03:54 PM
jstrdn90rs's Avatar
After running around town,and back to the dealer again,I finally found what I needed.Yes,the bulbs and sockets that arent removeable are PC(PC 194 or PC 161) numbers they are complete assemblies,these are the original ones.I tried breaking out the bulbs and installing standard 194 bulbs(had to move the contact wires over the sides of the tabs on the socket to work)ANyway,I went back to the dealer and they cannot order just the sockets..SO FORGET THAT..took a chance and hit another Auto Zone and whata know they had 194LL bulbs and the sockets..two different sizes.The Part no.is 85835..by motormite.They have a 1/2 and 5/8 size and our dashes take the 1/2 .I got the last two on the shelve..So I also understand that the 194 bulbs are mainly used for illumination and the 161 bulbs are used for idiot light or indicators lamps.Again I hope this helps for someone dealing with this issue.
Old Jul 12, 2006 | 05:08 PM
jstrdn90rs's Avatar
Does anyone have them white overlays and some LED blue or white bulbs in them?...I am considering installing a set and would like to see if anybody has a pic of day and night to see how they look?..
Plus,if you have the LED lights.. I understand the dimmer wont work on the LED's? is this true?
Old Jul 12, 2006 | 05:18 PM
krisb410's Avatar
I have white LEDs and they dim with the panel lights, I just order white face overlays and amber LEDs. So I'll post some pics when it's all installed. Check these guys out www.superbrightleds.com/carbulb-notes
Necron
Brakes
Sep 14, 2015 12:45 PM
CAMAROBEAV
European Region
Sep 12, 2015 10:04 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
katrav8
Sep 11, 2015 09:00 AM
84 TA NV
Sep 6, 2015 08:02 PM
